capacitator & distribution blocks question
Old Feb 13, 2003
velocity's Avatar
velocity is an unknown quantity at this point
how much do they cost????
Old Feb 13, 2003
LudlamTheory's Avatar
i boogie for the raindrops
distro blocks, between 10 and 150 dollars
caps... between 40 and 3,000
be more specific
Old Feb 13, 2003
velocity's Avatar
well i have 2 amps and 800 and 660watt i have them hooked up by one power wire to the battery and when the wire reachs the trunk the wire is spliced so it can power both amps i was told this is the wrong way. i was also told i had to much power to the battery. so i want to get it done corectly. what will i need to do this and what is the right way to power to amps by only having 1 power wire??
Old Feb 13, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
The correct way to do it would be to get 1 ground distribution block (around $20-$30). They normally have 1 input of 4 or 8 guage and 4 ouputs of 8 guage. Run your single ground into it and then 1 out to each amp. Also you should get 1 fused power distribution block ($30-$40) and fuses. These also mormally are 4 or 8 guage in with 2-4 outputs of 8 guage. Run 1 output to each amp and put a fuse in the block that matches the draw of your amplifiers. Also make sure you still use a fuse under the hood, the fused distribution blocks are not designed to replace that.
You really don't even need distro blocks but to do it the proper way, then you should have them. Who over told you that you had too much power to the battery has no idea what they are talking about.
Old Feb 13, 2003
velocity's Avatar
well i got my electrical system checked and they said the battery was drawing to much poer or something like that because of mya ftermarket stereo system they said it can kill the battery of the car
Old Feb 13, 2003
custom2k1's Avatar
You shouldnt have problems with draining the battery as long as your alternator is fine. If your worried about it then you can add a 1 farad cap or even 2.
NoobyKid
Jul 18, 2015 02:01 PM
hondadriver95
Jul 13, 2015 09:43 PM
NoobyKid
Jul 13, 2015 07:53 AM
ballmich
Jul 9, 2015 11:59 AM
Hqly2001
General
Jul 8, 2015 04:07 PM
