Where to ground!?!
Old Feb 4, 2003
salokod's Avatar
salokod is an unknown quantity at this point
Where to ground!?!
I know this is probably on the board somewhere, but im too lazy to look. I have all the wires ran back there and hooked up but the amp does not turn on!?!? 1st question... will the amp turn on if it's not properly grounded? 2nd question... where can i ground it? right now i have it on a shock bolt? please help
Old Feb 4, 2003
orso's Avatar
orso is an unknown quantity at this point
um..... wrong forum.
and to answer your question. If it is not grounded then it will not turn on. the shock bolt should be fine. maybe you should check your turn-on lead. did you put the fuse in. did you hook it to the battery.
Old Feb 4, 2003
salokod's Avatar
i think my problem is i don't have it tightened down all the way, sorry about the wrong forum, im going to go try to get a bigger bolt and tighten it.... thanks
Old Feb 4, 2003
salokod's Avatar
[IMG]i/expressions/face-icon-small-confused.gif[/IMG] i really don't know what's wrong, i checked the remote turn on, i checked the power, i had the groudn on the bolt (but it wasn't tightened down all the way would that matter?) i feel so dumb[IMG]i/expressions/face-icon-small-nono.gif[/IMG]
Old Feb 4, 2003
salokod's Avatar
can someone just drop me where they grounded theres?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 4, 2003
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
i grounded mine to a bolt behind the back seats but i took mine out a while ago. That's the only reason I could see the bolt. Just get a self tapping screw and put right between were the back seats fold down.
Did you check to see if there is a fuse inthe AMP wire?
(i'll post a pic in a minute)
Old Feb 4, 2003
salokod's Avatar
what do you mean a fuse in the amp wire, i have a fuse in the power wire? that what you mean?
Old Feb 4, 2003
salokod's Avatar
so your saying just get a screw that i can just turn in, and put it there and ground it there?
Old Feb 4, 2003
yeh
i meant to say amp wire
i had mine had blown when was connecting mine once and i just upgraded to a bigger fuse
besides that, just check al the connections and make sure their tight and in the right spots
EDIT
Yes, you can get a self tapping screw and just drill the ground there. It'll keep in snug and wont go anywhere.
Old Feb 4, 2003
salokod's Avatar
thank you sir, i will be trying it tonite and i'll post it if it works
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Bricoleur
Sep 9, 2015 12:23 PM
