2 10"s OverKill?
Old Dec 4, 2002
scrible's Avatar
scrible is an unknown quantity at this point
2 10"s OverKill?
ok right now on my setup I have this:
Optima Yellow Top
200amp Iraggi Alternator
All wireing is Stinger Expert Series
1 Stinger Expert Series 1Farad Cap.
DEI Studio 5.25" 2-way Component System (pair)
-- Directed 2400 Amplifier - 125x2 @ 4ohm - 400 watts RMS total
- These are going in Q-Logic Kickpanels
DEI Studio 6.5" Midbass/Midrange Drivers w/ Crossovers (pair)
- These are going in factory door locations
DEI Studio 10" Subwoofer w/ 4ohm voice coil - 400 watts RMS (pair)
-- Directed 1100d Amplifier - 1100x1 @ 1ohm (watts RMS)
- These are going in a dual sealed 10" box behind the seat
This is all going into a Single Cab S-10 for an SQ setup.
Question is about the subs is 2 10" subs on a mono amp an overkill for this system or will that be great?
Or should I go with only 1 10" in a Q-Logic Custom S-10 box and downgrade the amp for right specs..
Old Dec 4, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
I'm running two 10W3's in my car with a MTX 6500D mono block amp with stock speakers powered by the stock HU and sometimes I don't think it's enough. I don't think you'll like one 10. Maybe one 12 but if you are going with 10's I would recommend at least 2. I think this'll be great for you setup. Lemme know how it sounds! [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 4, 2002
scrible's Avatar
ttt?
Old Dec 4, 2002
fonto's Avatar
The LA Clipper
I think your system will sound great with the two tens If they are too loud then turn down the gain
Old Dec 5, 2002
mohawkboom's Avatar
with th studio subs..you'll need the pair or your midbass will out do your bass [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..
Ray Darvi
Aug 12, 2015 11:55 AM
Zordrack
Feb 26, 2015 06:49 PM
novice121
Jul 4, 2014 05:23 PM
MetalBear
Jun 1, 2014 11:50 PM
