Stuffed wire thru firewall
Old Nov 27, 2002
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I put an amp powerwire thru the grommet in the passenger footwell. im afraid water might get in, should i be concerned? i just stuffed it in there with that other bunch of wires.. maybe i should tape it up? it seems pretty low to the ground where water might be
Old Nov 27, 2002
dragoon's Avatar
i did that too, but i don't think it should be a problem.
Old Nov 27, 2002
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
It's a double rubber grommet don't worry about it, and you would have to be in a torrential downpour for water to soak it enough to ruin it, you'll be fine.
Old Nov 27, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
I don't think water can even reach that area... can it?
Old Nov 27, 2002
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
i was just wondering why the firewall grommet is down by the kickpanel on the passenger's side. if you pop open the hood and check out the wires going into the dash, its clearly on the top right behind where the heating vents above the stereo is. how does it go from that location all the way down to the kickpanel? i'm confused.
Old Nov 27, 2002
Falcon's Avatar
Falcon is an unknown quantity at this point
ziggy,
there are a bunch of different gromets in the firewall... likely you are thinking of another
Old Nov 27, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
you prob wont have a water problem
Old Nov 28, 2002
Amer786's Avatar
Senior Member
Amer786 is an unknown quantity at this point
what is gromet?
Old Nov 30, 2002
i dunno, but its seems like a power wire that is originated from the battery.
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
