amp power connection
Old Nov 17, 2002
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
ive had my system hooked up for a while, i have a 600 watt amp powering my subs, and i used 4 guage wire, i have a kenwood amp and both the + and the - power terminals are right next to each other, and the slots for them are really small, i dont know why, the fork like connectors that go on the end of the wires dont even fit in the terminals, so until now i have been grinding the edges down so that they would fit, but if the subs move a little bit the forks break! so theres gotta be another way of doing this! help me ? how and where can i get the stuff?
Old Nov 17, 2002
LudlamTheory's Avatar
i boogie for the raindrops
you dont need the forks... you can just stuff a small end of the wire under the 2 little plates that clamp down on each other, it'll be perfectly secure.... before i cared for appearance, i had it like that for some time
Old Nov 17, 2002
Mbow's Avatar
You can do that but then you take the chance of a strand of wire reaching over and touching the opposing terminal.
Best resolution IMO - get a distribution block and a foot or so of 8 guage wire. Run the 4-guage to the d-block (I have mine mounted right next to the amp) then run an 8 guage wire(s) out the other side to your amp(s). I can take a pic tomorrow if you'd like for more clarity..
EDIT: You could get a gold plated d-block for less than 10 bucks, and a couple feet of 8 gauge for like $0.50, and some more 8-guage spades for a few bucks. ~$15 bucks and you'll never have to worry about it again. Plus, you'll have very nice, clean, and secure connections.
Old Nov 17, 2002
this distribution block is a good idea, i never really thought of that... but where do i get this block from?
Old Nov 17, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
You can get a distrobution block from any car audio store.
Old Nov 18, 2002
andyman97's Avatar
Turbo Guru
Something else that you can try is mounting the amp on the sub box itself, that way you don't have to worry about the box moving and breaking connectors.
Old Nov 18, 2002
already mounted the amp to the back of the box. .
Old Nov 18, 2002
andyman97's Avatar
Turbo Guru
Then are you still having problems with the spades breaking?
Old Nov 18, 2002
Mbow's Avatar
They don't fit because they are made to except 8-guage wire not 4. Check out my link in the sig and there is a pic of my amp and d-block.
Old Nov 18, 2002
andyman97's Avatar
Turbo Guru
Get an 8 gauge spade, trim the end of the power wire so that you can get as much wire as possible into the spade, crimp it and you should be good to go!
Old Nov 21, 2002
ill go buy some 8 guage spades instead, thanks alot for the help guys
Old Nov 22, 2002
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
I would start be securing the box in the trunk so it doesnt move also. It sounds like you dont have much excess wire back there. Might wanna consider the d-block also to give yourself some extra slack.
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
jru27
Jun 19, 2015 03:51 PM
OPGForce
Feb 7, 2002 09:43 AM
SLeePeR012
Jan 7, 2002 12:24 AM
PimpBot5000
Nov 26, 2001 07:15 PM
