Measured our tunk. Here's the measurments I got.
Old Nov 11, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
Got bored yesterday so i decided to measure the trunk so I could start designing my amp rack and enclosure... Which I should have around mid december.
When I measured all of these I was behind the car (duh) so the stuff listed as front is actually the back of the trunk.
All measurements are with the trunk liner out and they're in inches.
Front width at the floor - 57"
Front width at level above the floor - 59.5 (There's about 3 levels in the front)
Front Width Widest - 60.5
Front Width at top - 56"
Width of Door (opening) at top - 45"
Width of door (opening) at bottom - 29"
Bottom of door (opening) to floor - 7.5"
Bottom of door to spare tire place - 13.5
Spare Tire place to floor - 7"
Width between the less wide pieces - 54" (I have no idea what these are if you remove the trunk liner you'll see them)
Width between wheel wells - 42.5
Top of trunk to floor - 19.5
Top of trunk to spare tire place - 25
Lowest top to floor - 16.5 (Right at the back of the rear seat there's a bar that goes across)
Lowest top to Spare tire place - 23
Back of trunk to wheel well back - 19 (the wheel wells have an angled piece at the front the part closest to the rear is the back)
Back of trunk to wheel well front - 21.25
Front of trunk to wheel well back -21
Front of trunk to wheel well front - 14
Old Nov 11, 2002
WhiteRabbit's Avatar
good luck to you, i wasnt able to figure out a way to fit a box in teh trunk that would easily slide in and out for a 15" that was larger than 6 cubes net.
with 12's or 10's your job will be easier (baffle) but i wish the best of luck to you!
Old Nov 11, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
thanks, i needed that so i can start building my next box. i was just going to wait till next spring since my box is kinda glassed into the trunk. but now i can just start makin it [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Nov 13, 2002
JohnDoe's Avatar
I'm going with 2 12W7s so I think I should be ok.. I'm also going to try and make the enclosure use some of the space from the spare tire dip so I think I should be ok.
Saratoga
26
Oct 2, 2015 09:05 PM
JMKendrick
Sep 16, 2015 06:17 PM
Donahue
Sep 8, 2015 09:00 AM
amrhamed
Sep 1, 2015 06:27 PM
cukaracha
Jul 23, 2015 08:50 AM
