Cutting Glove Box help
Old Oct 20, 2002
Cypher's Avatar
Cypher is an unknown quantity at this point
I want to cut out a square in my glove box so that i can integrate my CD changer into it. Because as you know it wont fit inside and it would look different. I've seen the pic of someone cutting out a space for a playstation. But my question is what tools do you pro's in DIY recommend in doing this so i get a good clean cut without getting jagged edges. The box is basically plastic but is some what thick. thanks guys
Old Oct 20, 2002
WhiteRabbit's Avatar
rotozip or dremel, plus lotsa sandpaper
Old Oct 20, 2002
Cypher's Avatar
i have a very old dremel that has a cutting blade attachement. But when i look at the blade it looks so thin. Im afraid it might break its like razor blade thin and only about 1 inch in diameter should i use that ? thanks
Old Oct 20, 2002
mohawkboom's Avatar
that'll do fine...just cut slowly and be as precise as possible....cut the whole at least 2mm too small on all ends and sand from there for an exact fit..
Cheers
Mohawk
Old Oct 20, 2002
Cypher's Avatar
sounds good thanks guys [IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Old Oct 22, 2002
Chapobapo's Avatar
Chapobapo is an unknown quantity at this point
hey cypher post a pic when done.
GotSiR
Jun 23, 2016 04:06 PM
mac25
Aug 21, 2015 11:14 PM
MrOldskool
Aug 18, 2015 09:58 AM
JetsterDajet
Aug 16, 2015 01:56 PM
