another easy capacitor question
Old Sep 6, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
im lookin to put a capacitor in my car and have a couple ?s. ok, first, im just running a 250/1 jl right now, but later ill be running a 500/1, 300/2, and 300/4. now the ?s
1. will a 1.0 farad cap(in preparation for the bigger system) be excessive and a waste for now with only a 250/1 pullin from it, or should i get a .5 farad for now, and then get a 1.0 farad cap, and use both later?
2. when you wire one cap, does it get wired like this?:
power)-----(+cap-)-----(+amp-)-----(sub)
meaning in series? or in parallel?
Old Sep 6, 2002
WhiteRabbit's Avatar
wire in parrallel.
and 1.5 farads of capacitance will make more of a difference, if any, than 1 farad, but is also almost twice as expensive.
decision is up to you entirely.
but its literally impossible to have overkill on capacitance. (unless you get stupid [IMG]i/expressions/face-icon-small-wink.gif[/IMG] )
Old Sep 6, 2002
ok, now im jsut wondering about how fast the system, current and future, will discharge them, also, when discharged, how long does it take to recharge them. i asked someone at tweeter, but i want to hear some other peoples answers.
thanks, btw.
Old Sep 6, 2002
duty cycle is faster than takes for a man to climax after having no relations for 4 years.
when the first bass note hits (ideally) the cap discharges completely and recharges ready for the next bass note in the song (again, ideally)
Old Sep 6, 2002
ok, so i should go with 1 farad, or 1.5, or is a .5 sufficient for future plans, im not sure waht you mean by your first post
Old Sep 6, 2002
I would personally get all your other stuff first.
when you have the ENTIRE system done, see how bad yoru dimming problem is. THEN consider investing in a cap. or two. or three.
Old Sep 6, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: WhiteRabbit
when you have the ENTIRE system done, see how bad yoru dimming problem is. THEN consider investing in a cap. or two. or three.[hr]
Agreed..
Also Two 1 Farad caps wired in Paralell have a lower ESR than a 1.5 Farad cap..and would cost about the same...
I use One 1 Farad cap merely to keep voltage as stable as possible for best sound quality. But I lose 1.3DB's at full power because of the added resistance
Old Sep 6, 2002
ok, ill get a 1 farad for now, and when i upgrade, if i need more ill get a second and wire it in parallel. thanks guys.
civic98?
Aug 13, 2015 01:32 AM
Mr.Beefy
Aug 12, 2015 04:39 PM
cecisd15
Aug 11, 2015 02:53 PM
sf3r8z
Aug 11, 2015 02:32 PM
NoobyKid
Jul 13, 2015 07:53 AM
