Quesiton about neons
Old Aug 13, 2002
2k2civic's Avatar
I'm just wondering how much power the typical 12" neon uses? I want to hook up a few (maybe just two in the front, or maybe two in the front and two more under the front seats for the rear) and have them controlled with the pin switch that controls the dome light. What do you guys think? Should I just play it safe and run it with a relay and have the realy controlled by the dome light switch?
Old Aug 13, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
neons dont take much power at all. i think its somewhere around .25 amps or something
Old Aug 13, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
I would use a relay any time you add something to the electrical system. If Honda didn't put it there, then it wasn't meant to be there. So use a relay and fuse your power source. By the way you would probably have to use a relay anyway because your dome light is probably a negative trigger so you would have to reverse polarity.
Old Aug 14, 2002
VNlilMAN's Avatar
The Standard One
ya i'm pretty sure the dome is a -
Jeffdp
Jun 18, 2015 06:18 PM
fraga
Sep 19, 2005 10:58 AM
Maestro
Mar 21, 2002 11:01 PM
viper775
Mar 5, 2002 04:44 AM
SLeePeR012
Mar 2, 2002 11:00 PM
