80 Amp Alternator Upgrade
Old Dec 6, 2024
Jeanelliellie's Avatar
Mother of Vicci
Jeanelliellie is an unknown quantity at this point
Has anyone gotten one of the 80 Amp alternators from oriellys or autozone for their 7g (as opposed to the 70 Amp oem spec ones)? If so, what was your experience with it? It's a small upgrade, but wondering if it's enough to give extra juice for better stereo (stock) performance and better charging in winter time.
And my current alternator is working as it should, it's just the oem 70 Amp ones are kinda wimpy as we all know.
Old Dec 7, 2024
Colin42's Avatar
Re: 80 Amp Alternator Upgrade
These cars dont like aftermarket alternators
Old Dec 8, 2024
Mother of Vicci
Oh, what do you mean? Not that I'm doubting your advice, I just see a lot (read: more than one lol) of posts about getting really snazzy 160+ amp alternators for serious audio setups in our cars. Do you just mean non-oem direct replacement parts from AutoZone?
Old Dec 8, 2024
Fantastic11's Avatar
Fantastic11 is an unknown quantity at this point
I've never upgraded an alternator on my Civic, but if I were you, I would try to find a model made by Denso that would supply you with what you need. Denso is the OEM for the alternators in 7th gen Civics.
It looks like the 2nd generation CR-Vs used a 90 amp alternator. So a DENSO 2104168 would do the trick once you figured out how to mount it correctly. They use the K-series motors as opposed to our D-series, so I imagine they won't just swap right over.
Old Dec 11, 2024
hondas does not like aftermarket electronics, they just start causing issues in no time.sensors, alternators, etc.
Old Apr 16, 2025
Mother of Vicci
To follow up: after further research, it looks like the symptoms I was looking to fix with a beefier alt are more due to poor factory grounds. To anyone looking into better recharging in their 7g civic: Replace the battery > engine and engine > frame grounds with some large gauge straps, and add a battery > frame ground. Night and day difference in headlight/dash brightness, radio performance, cold cranking power, and engine response for like $25.
Jasdip
50
Jun 28, 2007 05:48 AM
ja590
Oct 2, 2004 04:45 PM
dru106
Aug 16, 2003 12:26 AM
LudlamTheory
17
Feb 12, 2003 10:19 AM
3dStylz
Sep 3, 2002 10:19 PM
