05 lx a/c whole system going off randomly
Old Oct 13, 2018
Andym's Avatar
Andym is an unknown quantity at this point
05 civic lx 124,000miles only owner me,
the a/c system and cabin blower shutting down randomly, at first I thought it was the battery and replace it and I also cleaned the battery ground that goes to chassis and engine but it didn't change nothing. Also the headlights flickering when it happens
I'm guessing I can't be the only with this issue?
Old Oct 14, 2018
Re: 05 lx a/c whole system going off randomly
What about lights flickering?
If the blower fan in the dash quits, the HVAC system WILL turn off the AC compressor.
Fix the blower fan problem first.
If you can smack the bottom of the fan motor and it starts working again, the motor is bad. (or wiring problem, but motor failure is probably more common)
I don't suspect the power transistor yet because you seem to indicate the fan only quits intermittently.
Old Oct 14, 2018
Andym's Avatar
Wow, thanks you so much for letting me know, now I know where to focus on cause the fan motor have been making a noise on lower-med speed like sign of wear.
The first symptoms I once noticed was flickering dashboard instrument lights, the radio went off and air system too, that happened once and I thought immediately it had to be the battery since it was a Walmart low cost battery and not exact fit which I used for over a year. I replaced the battery for other brand but the problem continues now with the dashboard fan motor hvac and headlights flickering at night​​
Old Oct 15, 2018
Andym's Avatar
mightymouse0325
Electrical
Aug 29, 2019 02:30 PM
Possum-Pie
Jul 30, 2018 04:22 AM
Sionolann3
Mar 15, 2017 01:30 PM
anlo
Dec 29, 2016 01:53 PM
Stopka
19
Sep 23, 2016 12:33 PM
