Remote central locking not working?
Old Jun 10, 2016
Steven Corns's Avatar
Steven Corns is an unknown quantity at this point
I've tried all the steps of ew programming my key fob and they all work up until I go to test it the car will lock from outside and in where nothing happens.
Key fobs battery and car batter is fine and both work.
It's a 2004 1.6.
The key fob worked and could lock and unlock the car fine then suddenly stopped.
Old Jun 10, 2016
Colin42's Avatar
Re: Remote central locking not working?
Test the lock actuator for the drivers door, it's the 'master' and the other ones are slaves. When I bought my car the power lock actuators for both of the drivers side doors had failed, so the key fob wouldn't do anything. Replaced the drivers door actuator and the fob worked again. Had to repair the wiring in the door as well as replace the actuator to get the rear door working again.
Old Jun 10, 2016
I don't think it will be that because the doors lock with the key or the switch on the driver's door that locks them all?
Old Jun 10, 2016
Colin42's Avatar
So when you use the lock switch on the door it will lock and un lock all 4 doors? Then the problem probably lies with the receiver module.
In this thread the guy put keyless into a car that didn't have it originally. Might have some useful info: https://www.civicforums.com/forums/2...r-2002-lx.html
jessica19699
Feb 12, 2016 04:57 AM
Joelship
Feb 11, 2016 09:23 PM
Kristoco
Feb 7, 2016 01:06 PM
Sep
22
Jan 29, 2016 01:06 AM
steve6
Nov 22, 2015 08:18 PM
