Civic LX High beams not working
Old May 7, 2014
biggy's Avatar
biggy is an unknown quantity at this point
Hello, i'm new here, i read a couple of threads, but i couldn't fix my problem.
So, i have an issue with my high beams, are not working all the time, i checked and replaced the switch, checked fusese, checked the drl (found here a topic). The bulbs are good. When high beams are not working i can hear a noise from the right side, inside glove box compartiment, i can't figure exactly from where. I guess this is a common issue and someone can help me with this. I really appreciate any kind of help.
Old May 7, 2014
Re: Civic LX High beams not working
Sounds like the DRL controller is bad, needs resoldered.
Old May 7, 2014
biggy's Avatar
Already checked. I opened the module checked the connections everything is fine.
Old May 7, 2014
https://www.civicforums.com/forums/3...l-problem.html
(link)
Posts 7 and 12 have pics, post 23 has a video
Old May 7, 2014
biggy's Avatar
Thanks, found that. I noticed that when are not working from the right side is coming a noise. Could be there a relay, another module? In this moment i doubt it is the drl.
Old May 7, 2014
Seems like everyone else says a relay buzzes behind the glovebox when the DRL controller goes bad. Many DRL threads seem to mention the buzz noise anyway.
Fix is usually a DRL controller-- or resolder it.
I'm in the US, we didn't get DRL on 7th gen Civics.
Old May 7, 2014
biggy's Avatar
Thx, i ll open again the module i ll resold all the connections, hopefully will work thx for your time and help.
Old May 7, 2014
It's consistently the pins for the 2 relays attached to the board that break the solder joints.
I'd just retouch all of them if it were me.
Old May 7, 2014
biggy's Avatar
So, i checked and retouch again all solder joints, but the result is the same, also i tried to suspend the drl module, if i unplug the drl connector the high beams are not working at all, but if i leave the drl module connected and pulled off the drl fuse, i can hear the same noise and blue light (dashboard) is working but the high beams not...
Old May 8, 2014
CraigW's Avatar
What happens if you leave the brake set after startup ??
High beams work then ??
Old May 8, 2014
I guess it's time to quit guessing then. Get a wiring diagram and voltmeter and diagnose what's actually happening.
Old May 8, 2014
CraigW's Avatar
https://www.civicforums.com/forums/a...2&d=1232212860
https://www.civicforums.com/forums/a...3&d=1232212860
https://www.civicforums.com/forums/a...4&d=1232212860
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
Braun
Apr 23, 2015 09:03 PM
vtechcivic
Apr 21, 2015 06:58 PM
