Dying Turn Signals
Old Mar 18, 2014
WindmillHill's Avatar
WindmillHill
WindmillHill is an unknown quantity at this point
Dying Turn Signals
My 2001 Honda Civic has dying turn signals. When I activate either left or right turn signals, they sometimes come on, but they blink for only a second or two and then stop.
I changed out the turn signal switch and it didn't fix the problem. Still does the same thing.
The flashers work fine.
Do the flashers and turn signals use the same relay? If so, what could be causing this problem?
Old Mar 18, 2014
Poopies's Avatar
Super Moderator
Re: Dying Turn Signals
I would have thought so, but you can check the fuses too. Blinkers get weird when their fuse is on its way out.
Old Mar 18, 2014
There is only one flasher, it is in the fusebox under the dash. It's used for both turn signals and hazards.
Turn and hazard systems use separate fuses.
I'd have a wiring diagram and a voltmeter. Test, don't guess.
trellex
May 24, 2015 04:39 PM
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
my2k1vic
Jan 8, 2002 08:31 PM
