Default guage brightness when headlights are on
Old Jul 19, 2012
johnr0563's Avatar
johnr0563 is an unknown quantity at this point
I have an 03 Civic sedan and on the guage cluster it has the **** to adjust the brightness. I have my brightness all the way up. However, when you turn on the headlights, the brightness goes down a notch.
Is there any way to make it so that when the headlights come on it doesn't dim the guages? It's just a pain to always adjust the brightness back up each time I put the lights on.
Thanks
Old Jul 19, 2012
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
Re: Default guage brightness when headlights are on
I believe you just turn it all the way up with your lights on and that becomes the setting..... I have mine basically off when the lights are turned on and im pretty sure thats how I did it.
Old Jul 19, 2012
I believe that's correct too.
Adjust dash brightness with the headlights off, then turn the headlights on and readjust the dash brightness again.
Old Jul 19, 2012
sl33pyriceboi's Avatar
yes, its an auto feature.
its better to have a dim cluster and a dim cabin at night...tht way you can see the road better.
Old Jul 19, 2012
if its the new cluster with blue or red rings and white numbers (03-05 lx/ex), then it has two brightness saves. one for park and one for daytime. so if you want full bright at night, you simply turn the park lights on, then turn the dimmer **** of the cluster to full bright and it will save it. but imo, the new clusters are way too bright for night driving on the daytime setting. older cluster (01-02 lx/ex and 01-05 dx/vp) does not have separate brightness memory.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
IronFist
Sep 25, 2015 07:13 PM
Dave Brabant
Sep 10, 2015 06:48 PM
MamaBear2015
Sep 4, 2015 09:04 PM
