Compound electrical problem, not sure where to start
Old May 20, 2012
westsidesneo's Avatar
westsidesneo is an unknown quantity at this point
Hi, new forum user here. I'll get straight to the problem:
I set out yesterday to change out the factory radio for something nicer. Everything was going smoothly, I had the "something nicer" radio hooked up with a wiring kit, and was doing a functions test when I hear an electrical pop from the dash area, and the radio went dead. I'm 99% certain it wasn't the new radio. I reinstalled the stock radio and it's nonfunctional as well, as well as my keyless entry system and power locks. The power locks only work when the car is running, but the keyless entry doesn't work period. I can reprogram the keyless entry i.e. get positive feedback from it while programming, but it nevertheless will not lock/unlock. I have replaced the #8 and #9 fuses.
Thanks for any help, fellas, I appreciate it.
Old May 20, 2012
CraigW's Avatar
Re: Compound electrical problem, not sure where to start
Locate a fuse named "back up" (not sure of model year) It supplies constant power to various items.
Old May 20, 2012
I have a 2003 coupe. I replaced the fuse, everything seems to be in working order now. You, sir, are a scholar and a gentlemen and I am an idiot lol
Old May 21, 2012
CraigW's Avatar
Pretty common problem around here from time to time.
Old May 23, 2012
2009civic's Avatar
2009civic is an unknown quantity at this point
Seems like you touched the dimmer wire to metal. Check all fuses.
Old May 23, 2012
04 Honda Civic's Avatar
Next time disconnect the negative (-) black wire from the battery. It will cause things not to short out if they are touched together.
CarStuff
Dec 6, 2020 12:52 PM
WLakers
May 4, 2015 06:23 PM
SSMatey
Apr 13, 2015 06:09 PM
black2k1vtec
Dec 6, 2001 09:49 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
