Change cluster..!!!! Help
Old May 14, 2012
Martillo's Avatar
Martillo is an unknown quantity at this point
I have a 2004 civic DX and I want to change the cluster to the EX,,I plug it in and nothing happens, I do and as I do.???
Old May 15, 2012
Re: Change cluster..!!!! Help
um, only the 01-02 lx/ex clusters are a direct swap. if you got one of the fancy looking 03-05 lx/ex LED clusters with blue or red rings, you need to completely rewire the connectors.
Old May 15, 2012
Martillo's Avatar
I know they have to rewire,,, I found the diagram of civic dx 2004 but I need the diagram as I have to organize it. Somebody have it?
Old May 15, 2012
https://www.civicforums.com/forums/1...faq-video.html
Old May 16, 2012
Martillo's Avatar
gearbox thanks for your help, but now I have a concern,,, with wires which I can test whether the cluster work?
Old May 16, 2012
you need all the wires connected to test that. each wire does something different (one for lights, one for tach, gas, odo, warning light, etc).
Old May 16, 2012
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
i went into this swap blind i did it too and the wiring diagram in the thread that gear posted is exact the only thing is you have to tape off a wht/red wire as it is not used in the new harness arrangement. the paperclip pin popping technique is also spot on and worked perfect the first time and everytime just follow that diagram exactly and if you dont want to unplug your battery just be very careful and make sure no wires touch thats what i did its risky but doable and also im not sure if you know but mileage is stored in the cluster the the ecu like my frame engine and trans is at 119k but the cluster reads 185k miles i have yet to figure out how to roll it back or find a shop that does.. but to conclude follow that wiring diagram exactly and i ignore the abs light if you want to fix that you will have to read into that thread some more
Old May 18, 2012
Martillo's Avatar
Everything is working except the gas level and right signal,,,what I do.???
Old May 18, 2012
Martillo's Avatar
I put the DX cluster back and cut the black and yellow, and that is the fuel level because stopped working,,,, buti test in the EX cluster in all pins free spaces and however does not work,,,
Old May 18, 2012
Martillo's Avatar
I do it the easier,, look at this ---- I have the 2004 DX blk / yel = gas, in the diagram EX does not appear blk / yel,,, and these are the I have connected,,,, pnk / blu = 3, wht / grn = 6, wht / blu = 7, blu = 8, wht / red = 17, yel = 18, blk = 22,,,,,,in the harness blue plug not appear grn/yel=right signal indicator...these are the only 2 problems that remain, such as I can solve.?
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
BootyDo
May 7, 2015 04:46 PM
andjosaus
Apr 28, 2015 10:02 PM
silverdevil
20
Jun 2, 2007 04:42 PM
htowncivicEX
Jan 21, 2002 11:48 AM
