Nothing but static
Old May 27, 2010
Pestra01's Avatar
Pestra01 is an unknown quantity at this point
Nothing but static
I replaced the factory radio with an alpine unit becasue the radio was getting nothing but static, the new head unit also gets nothing but static and i know the antenna built into the glass doesnt always work out well any help on how to fix it would be greatly appreciated
Old May 27, 2010
Re: Nothing but static
make sure the antenna plug is connected, and also the power antenna wire. do you have coupe or sedan? or hybrid?
Old May 28, 2010
Pestra01's Avatar
I have a 2001 EX Coupe The antennae into the back of the player is plugged in. There is a blue wire that says Antennae boost or Fm Ant on it that has no home in the wiring harness could this solve my issue or should i look into the antennae module and resistor in the trunk?
Old May 28, 2010
BlueEM2's Avatar
Whachya lookin at?
The blue wire is the antenna booster. It will help but I don't think that's your problem. Definitely take it back apart and hook it up. Even without the booster hooked up you should get some reception. I find my window antenna works pretty good. I wonder what it could be hmm.
Old May 28, 2010
you need to hook that antenna wire up. i can check the wire color for you later today in the honda book. when i had mine disconnected, i had no fm reception at all. with it hooked up, fm sounds like cd quality.
Old May 29, 2010
electric130's Avatar
coupes have a powered signal booster that the blue wire needs to go to.
Old Jun 1, 2010
Pestra01's Avatar
I took the whole thing apart and still cant find a home for it if anyone finds out for me it would be much appreciated
Old Jun 1, 2010
Pestra01's Avatar
thank you everyone for your help...turns out after tearing the whole rear deck apart i found the antennae amplifier was not plugged in it looks like the previous owner jimmy rigged a wire around it and taped it so i took it apart and put it back together properly and now i have crystal clear radio!!!!! thanks again everyone
Old Jun 1, 2010
i can look up the actual wire color in the stock honda harness that it should go to tonight.
Old Jun 1, 2010
mikephinney's Avatar
mikephinney is an unknown quantity at this point
is this the same on the LX sedan? I installed a pioneer deck using a honda wire harness adapter, but I don't know if that wire is even there. I have decent reception but i get way better reception in my other vehicle. i did get the windows tinted (non metellic) and i don't think it changed much. if it's not a wiring issue is there any thing else I can do to get better reception?
Old Jun 1, 2010
it has to be that wire. i can check and see if its the same for coupe and sedan. on my ex sedan, i hooked up the wire and my fm sounds like a cd. very clear and crisp, and i have window tint too (cell phones and compass dont work well in the car, but radio is okay).
Old Jun 1, 2010
i just found it from an old post. you want to hook up the power antenna wire from the aftermarket deck to the oem honda yellow/green wire (thats a yellow wire with green stripe). look for it in the honda connector harness, not the aftermarket harness.
Old Jun 1, 2010
thanks Gearbox, will do
Kinneybrk
Jul 24, 2015 02:41 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
civicvtec1ps
Oct 5, 2003 07:56 PM
civicvtec1ps
Aug 31, 2003 01:34 PM
