Are the fuse panels different between models?
Old May 31, 2010
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
As you know, I'm doing a power window conversion on my DX. I got the ENTIRE wiring harness out of a 7 generation Si, not sure of the year. I got the huge spaghetti mess that goes from the kick panels to the fuse panel to the cigarette lighter to the gauge cluster and everything else. Problem is none of the wires that go into the fuse panel match what's in my car now. With the harness I have, I should have a duplicate of every plug going into the fuse panel because it should be the same harness with a few more wires. Honestly, maybe 2 of the plugs going into the fuse panel in my car now match plugs on this harness from the other car.
So I'm wondering if the fuse panels for both models are different. Do they for some reason use different shaped plugs to plug into the fuse panel?
And the fuse panel I'm talking about is the one under the dash which has all the fuses in it but also the entire upper portion of it has a whole lot of plugs plugged into it from the car's wiring harness. These are the ones I'm talking about.
Old Jun 2, 2010
DeX's Avatar
DeX
Canadian, Eh!
Re: Are the fuse panels different between models?
Nobody knows?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Black91civic
Jun 6, 2015 08:15 AM
EdGasket
May 26, 2015 06:19 PM
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
