need help with electrical
Old Dec 9, 2009
Tracy21's Avatar
Tracy21 is an unknown quantity at this point
Ok first off car wont crank because of injectors already narrowed it down to that but it is not the injectors themselves its the wiring to them im not getting any power to them i took them off and hotwired them and they work i jus cant get power to the injector plugs any ideas? thnx Tracy
Old Dec 9, 2009
Re: need help with electrical
retrace the wires, you could have a snapped wire somewhere
Old Dec 9, 2009
Tracy21's Avatar
i already checked the wires theres no snips or anything thats why im so lost is there any sensors or anything?
Old Dec 9, 2009
EK9_XCVI's Avatar
EK9_XCVI is an unknown quantity at this point
When you turn on your ignition, can you hear your fuel pump? If not you can start by cheching your PGM-FI main relay relay. This relay is located at the right side of the cowl.
One relay is energized whenever the ignition is on which supplies the battery voltage to the ECM/PCM power to the fuel injectors and power for the second relay. The second relay is energized for two seconds when the ignition is switched ON, and when the engine is running, to supply power to the fuel pump.
Old Dec 19, 2009
Tracy21's Avatar
i replaced the wiring harness and it works now thanx guys
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
