retrofit issue
retrofit issue
Ok i have a 02 Civic and i did a retrofit setup in my headlights with g35 projectors and bmw ballasts. Now my issue i have is i had made a wiring and it worked great but every once in while the right side headlight wouldn't turn on so i had to flick the switch on of couple times to get it to work. So what i have decided to do is re do the wiring and i found this diagram on here.
http://i16.photobucket.com/albums/b4...iagram01gb.jpg
This works great for lo beam. But for high beam it will not work.
http://i182.photobucket.com/albums/x.../G35ground.jpg
i got the projectors like this and the 2 wire plug is what controls the hi beam. What triggers it is positive and a negative. So what i did is ground the one side and hook the other to the hi beam but no luck. Also tried it with low beam.
Re: retrofit issue
yeah but you can switch them around, solenoids usually dont care which way you wire it. if it wont work one way, switch the wires.
Re: retrofit issue
85 and 86 don't matter on a standard relay. i'd recommend buying one that has a suppression diode in there so you don't blow up any electronics like i did. the relays are only ~$4.50 each. then the polarity matters. i think 85 is +.
https://www.civicforums.com/forums/1...iodes-now.html
Re: retrofit issue
the 6th gen civics headlights might be different then ours.
on our 7th gens, the +12v is alway on (constant) and the high/low beam is regulated by turning on/off the high/low GROUND connection.
im not sure but i remember reading the 6th gen civics being traditional H4's. meaning that the Ground is constand, and the hi/low is controlled by the +12v of the high or low turning on/off
here is a link to my harness i drew up from wt ive found
https://www.civicforums.com/forums/1...e-lowbeam.html
RiCeGrL
Feb 21, 2002 09:07 PM
