Unlucky day, signals and stereo
Old Jul 16, 2009
Erkm4n's Avatar
Erkm4n is an unknown quantity at this point
Hey everyone, so today me and a buddy of mine went to put on an aftermarket headunit on my 04 si anyways, it didnt work... thing wouldnt turn on I think it was short circuiting or something ended up blowing 2 fuses in the process. And about 3hours later we ended up putting the stock stereo back in and now that wont even turn on and even if it did i dont have the security code for it =\ and on my way home from his house i realized that my turn signals/hazard lights stopped working so i pulled over at the walmart to check the fuses and they were fine. Any ideas to what i should do regarding the signals and the no power to the stereo?
Thanks a bunch/
Old Jul 16, 2009
Re: Unlucky day, signals and stereo
you prolly forgot to plug back in the hazard light harness. it will cause all turn signals to stop working. and maybe blew some fuse in the process with the radio. check the fuses under the dash above the brake pedal and also under the hood by battery.
Old Jul 17, 2009
04 Honda Civic's Avatar
Yea I second what gearbox said. The signals wont work unless you replug the hazzard switch harness. As for the radio check the plug is getting power and check the fuse for the radio.
Old Jul 17, 2009
CraigW's Avatar
Check the "back up" fuse in under hood box and plug in the hazard switch.
Old Jul 17, 2009
Erkm4n's Avatar
Hah yeah I was kind of in a rush and forgot to put the harness back on the hazard light, that's working fine now, thank you. I just double checked both fuse boxes and everything seemed fine. I also noticed that the remote to lock/unlock isn't working either
Old Jul 17, 2009
CraigW's Avatar
Fuse #9 10 Amp "backup" fuse red in color... Just to the left of the H in the HONDA embossed in the plastic.
There are spare fuses in the box. Use the right size.
Old Jul 17, 2009
electric130's Avatar
Originally Posted by CraigW
Use the right size.
exactly. never put a bigger fuse in than what the manufacturer recommends. you can exceed the current capacity of the wire and cause a fire.
Old Jul 17, 2009
bigaudiofanatic's Avatar
bigaudiofanatic is an unknown quantity at this point
I got it fixed for him he is all set now. It was a fuse.
Old Jul 18, 2009
which one?
Old Jul 19, 2009
The one under the hood the 10 amp one. I didnt even see this thread until I got back I just used my volt meter, best tool I have.
Old Jul 23, 2009
Erkm4n's Avatar
Definitely man, the volt meter stands pretty high in my list of tools to get in the future
Old Jul 24, 2009
Ya man I have a fluke def worth the money
Lopes101
Jun 7, 2015 08:04 PM
4 banger
Jun 5, 2015 01:44 AM
Fastfebur
Apr 22, 2015 01:37 PM
