keyless entry/power lock issue
Old May 14, 2009
livinlarge89's Avatar
livinlarge89 is an unknown quantity at this point
I was checking an old deck of mine to make sure it worked, but I didn't have the harness that came with it. I spliced new wires onto my old harness to test the deck (just temporarily to check functionality), and it didn't work. So fair enough, it was a few years old just sitting there. I then removed the wires I spliced onto the harness (keep in mind that i didn't cut any wires at any point), and my current deck, once reinstalled didn't work, and my keyless entry won't work. My power locks only work when the ignition is on accessory as well. I was thinking that I maybe pulled the constant too hard or something and pulled it out somewhere else. With no wires actually cut I'm not quite sure what's wrong.
any suggestions? any help or advice is appreciated
Old May 15, 2009
CraigW's Avatar
Re: keyless entry/power lock issue
01-05 ??
"backup" fuse under hood box.
Old May 15, 2009
Thank you, that seems to be the general consensus with others as well, it was too dark to check last night, so I'll check later and post whether or not it worked
Edit: yes, it's 7th gen
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 18, 2015 07:37 PM
davidarenberg
May 16, 2015 08:45 AM
Shabba
May 13, 2015 10:55 PM
darwin-t
Apr 18, 2015 09:29 PM
