Best Place to ground amp in trunk?
Old Mar 12, 2009
phil6006's Avatar
phil6006 is an unknown quantity at this point
Exclamation Best Place to ground amp in trunk?
I searched, but I'm having trouble finding a good answer.
I have an Audiobahn 220W RMS amp (bridged at 4Ohm) powering my 8" JBL sub. I had originally connected the ground wire (approx 15" long) to one of the bolt things to hold the trunk carpet liner down. I knew that wasn't a good ground, but it was temporary. The problem with that is that the amp was overheating fairly quickly, and it would go into protect mode to avoid it dying.
Now I relocated the ground to another spot where one of those holding bolts used to be, after wire wheeling some paint off and drilling a new hole, figuring this should fix it.
It helped a little, but I drive around all day for my job, and after about 20 min of driving, the amp gets very hot to the touch, sometimes too hot to leave my hand there for very long. It doesn't get so hot that it goes into protect mode, but it has occasionally over the past few days.
I had this amp installed in my truck, and it gave me no problems up until the point I removed it.
I have the wrong kind of bolt now attaching the ground to the trunk floor pan (its made to go into a threaded hole - the original hole there was destroyed by my stupidity when I first got the car). Tomorrow I am going to find a large sheet metal screw to hold it down super tight, because, although it is fairly tight now, I can still move it around with my hand.
But I want to find a better place to ground so I don't have this problem. I am pretty sure that the problem is the ground, mainly because it helped a little when I switched it.
Can anyone please post a picture of where they have their amp(s) ground to in the trunk? Or at least explain where its grounded?
Thanks,
Phil
Old Mar 12, 2009
musicalcivic's Avatar
musicalcivic is an unknown quantity at this point
Re: Best Place to ground amp in trunk?
mine is grounded in my trunk on the left side of the car on a holding bolt w/e type of thing, there are 2 in ur trunk on opposite sides, i'll try n take a picture sometime to show you better.
Old Mar 13, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
just use a stock grounding area. if you pull the panel that houses the hook that the trunk latches onto you should see a grounding point right under it. unbolt it and put your ground there. thats the ground i used for all my set ups and its fine.
Old Mar 13, 2009
electric130's Avatar
i grounded mine on the ridge between the seats and the trunk. you can see it in the pic below. you can also see how i used hinges (due to the odd angle needed) to secure my sub box so it wasn't sliding around.
Old Mar 13, 2009
phil6006's Avatar
very cool. thanks guys.
Old Mar 13, 2009
phil6006's Avatar
OK so I found a good spot and it seemed to have fixed my problem.
I grounded it to the piece of metal that is behind the trunk carpet and in front of the drivers side quarter panel.
After a good round of sanding and wire wheeling, I was able to get a bolt through there and tighten it really well because I could get behind it to use a nut (with washers on each side of course). It about an inch to the back of the hold down nut for the carpet on that side, where you can attach a cargo net or something.
I saw the spot underneath the trim over the trunk latch where all the rear lights are grounded, but that seemed too crowded already, and small.
Old Mar 14, 2009
jamis33's Avatar
You Stay Classy, San Diego
that was actually the spot that i was going to reccomend
Old Feb 7, 2019
kevy678's Avatar
kevy678 is an unknown quantity at this point
hey what kind of bolt / screw did you use ?? I wanna do the same thing but I don’t know which bolt or screw will be the most secure connection there in that spot
Old Feb 7, 2019
BrotatoChip's Avatar
Super Moderator
You will need to use a self tapping screw of appropriate size.
pwnsauce
Audio DIY
Jul 24, 2011 08:06 PM
nickm748
Jun 22, 2004 10:32 AM
MegaHurtz
16
Apr 20, 2004 09:42 AM
eetfunk
May 12, 2003 02:15 PM
izmaxx
Apr 2, 2002 02:14 PM
