where to ground?
Old Mar 30, 2002
izmaxx's Avatar
izmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really nice
where to ground?
Where do you guys run your ground wire for your amps? I'm putting my amp in the trunk...
Old Mar 30, 2002
mohawkboom's Avatar
the seat bolt..right under your back seat [IMG]i/expressions/face-icon-small-smile.gif[/IMG].
Old Mar 31, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
I'm going to be mounting my new amp at the front of the trunk (under the latch basically), would it be safe for me to run my ground to the bolt you're talking about or should I find something closer?
Old Mar 31, 2002
WhiteRabbit's Avatar
its best to bolt as close to teh amp as possible. i personally use the screws taht hold teh carpeting down....there are four of them..... i crank them down with a locking wrench, i get a real good connection. you have to grind the spot first tho, otherwise, youll get a bad connection, but this is true no matter where you ground. I used a dremel. worked GREAT. (and no cables running from the cabin to teh trunk [IMG]i/expressions/face-icon-small-wink.gif[/IMG])
Old Mar 31, 2002
<< the seat bolt..right under your back seat [IMG]i/expressions/face-icon-small-smile.gif[/IMG]. >>
I always do that with installs with teh amp under the seat, but teh trunk?
Old Mar 31, 2002
mohawkboom's Avatar
Yeah. If you mount your amps on the back seats or close to them that's only a 2 foot long ground. If your using 4 guage it's More than sufficient..and no gringing.
Old Mar 31, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
I used the trunck latch, took it off, ground it down a lil, stuck the bare end of the wire in there, and voila! but i only have 8 guage wire, also the wire is run under everything, so you can't see it at all!! ut be careful if you ever are lookin for a ground and use a voltmeter, you can get false grounds, it happened to me once in my old car, looked like it should've been a good ground, and it was, for like one song, then the amp went into protection, o well, learn from your mistakes!
Old Mar 31, 2002
haha, oops, sorry, thought you said under the back seat bolt on teh front seat =p and id grind it no matter what.... no sence in taking chances....especially something so easy
Old Mar 31, 2002
mohawkboom's Avatar
the bolt isn't anodized and the threads on the bolt and the hole it goes are unpainted.. no need to grind and scuff paint.. from the trunk latch to the seat bolt there was'nt even 1 ohm of resistance.
Old Apr 1, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Right behind the rear seats there is a cross member. It will rise above a little bit. Just scrape off all the paint of this, make sure it is bare. Use a drill and a self tapping sheet metal screw witha regualr washer and a self locking washer, and drill in and you are done. That is what I did to my car. I will take pictures of it later this afternoon.
Old Apr 2, 2002
edy's Avatar
edy
edy is an unknown quantity at this point
I used the seat belt bolt for the back seat (EX coupe), seems to be working fine for me. Why such a big wire for ground?? I only use an 8ga wire, since that's what I had. Thinking of getting another power block dist. for the ground, much easier/cleaner than running 2 8 ga wires to the same area. Good idea/not? Don't waste the money?
Old Apr 2, 2002
personal preference.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Bricoleur
Sep 9, 2015 12:23 PM
