Viper 479v lost remote!
Old Nov 23, 2008
JJJ's Avatar
JJJ
JJJ is an unknown quantity at this point
hey I donno if anyone has this answer, but I lost my remote for the Viper resonder 2-way transmitter with remote start...I have a new one on order but I would like to know if there is anyway I could disable the alarm until I get the new transmitter remote? I do have a vallet button I believe next to the coin holder on the left hand side and I still have the key, would inserting the key and turning it on simply disarm it, I don't need to arm the alarm Ill simply lock the doors until I do get the remote.
Old Nov 24, 2008
TRIZ's Avatar
Re: Viper 479v lost remote!
just pull the power from the alarm?
Old Nov 24, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ if it were that easy viper wouldnt have a good name IMHO. im sure there is something more than to just pulling the power. i dont really know though lol.
Old Nov 24, 2008
D5cIvIc's Avatar
Yes, there is a way to turn it off. You have to use your valet button.
Go into the car (the alarm will be going crazy) and turn your key to the "ON" position.
Then you will press the valet button either 1-5 times (Present by your installter) within 15 seconds. Once you press the preset number of times, the alarm should turn off within 5 seconds.
If that does not work, you might have either got the wrong preset times or you waited longer than 15 seconds. turn your key to OFF and try it again.
Old Nov 24, 2008
D5cIvIc's Avatar
after you disarm, i'm not sure if the car will go in valet mode or not. If the car is in valet mode, your alarm light should have a solid glow to it. it should not blink at all. that's how you will know if you're in valet mode or not.
If the indicator alarm light is not a solid Red or Blue (depending on the color of your alarm light) then you will need to put it in valet mode until your remote arrives.
Go into your car and turn the key to the "ON" position again. this time just press the valet button "ONCE" only and wait for 10 seconds. after 10 seconds your alarm light should stay on.
To exit valet mode, just do the same thing again and the light should turn back off.
SammySC
121
Apr 7, 2017 07:43 PM
wingsfan19
Oct 1, 2015 03:45 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
meicalnissyen
Sep 22, 2015 06:20 PM
Dsmak
Sep 10, 2015 08:30 PM
