ac/heater
Old Oct 7, 2008
jtflipsi's Avatar
jtflipsi is an unknown quantity at this point
ac/heater
For an 03' Honda Civic Si . I have checked my system and i can't figure it out my heater control is not working i've checked both fuses, fan, the actual switch, relay and wires and it still won't come on. what could be the problem?
Last edited by jtflipsi; Oct 7, 2008 at 12:06 PM. Reason: missed a couple of things
Old Oct 7, 2008
jtflipsi's Avatar
Re: ac/heater
For an 03' Honda Civic Si. I have checked my system and i can't figure it out my heater control is not working i've checked both fuses, fan, the actual switch, relay and wires and it still won't come on. what could be the problem?
Old Oct 7, 2008
CraigW's Avatar
Re: ac/heater
What part is not working ??
No fan ? No heat ?
Old Oct 7, 2008
Re: ac/heater
have you checked the temp switch? sometimes it will go out and get stuck in one position, like it will be on cold and heater wont work, or stuck on hot and ac wont work. etc
Old Oct 28, 2008
Bdubb's Avatar
Bdubb is an unknown quantity at this point
Re: ac/heater
I have an 01 civic neither my heat nor a/c works on command. Sometimes when making a turn or hitting a bump my fans will start blowing hot or cold whatever it is set on. If I try to adjust it everything shuts down. Wasnt so much a problem in the summer but now I have no heat.
turboengnr
Interior DIY
230
Oct 14, 2020 09:47 PM
DamnYank
Mar 18, 2015 09:26 PM
phillycivic
May 10, 2013 02:18 PM
jmtikhonoff
Feb 10, 2013 04:17 PM
rucshaca
Apr 2, 2010 01:33 PM
