HID help plz (searched)
Old Jul 12, 2008
minorc's Avatar
minorc will become famous soon enough
I checked out many of topics on HID problems and decided to ask my own question, i have and HID for a 2003 civic coupe and i have tried numerous different wiring combinations and have came up with 2 solutions that actually work . When i turn on my lo-beams, the dash shows the high beam symbol but when i turn my hi-beams on it lights up brighter and the lights stay the same. I thought this kit had a different light for Hi and Lo beam, which is why there is a peanut bulb attatched to the light. Is this the proper way to install this kit or is my car going to catch fire in the next couple of days?
Old Jul 12, 2008
sl33pyriceboi's Avatar
Re: HID help plz (searched)
sounds find as long as you have the proper wiring harness. if they provided one and you installed it correctly, then ur fine.
does ur hid lowbeam stay on (actual light) when you turn the high beam on?
Old Jul 12, 2008
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
i had the same problem as you. you have something wired up wrong. damn i dont remenber how me and my friend fixed it though. but you're wiring isnt wrong i meant switched up.
Old Jul 14, 2008
TemjinX2's Avatar
its because you have a 03 so your have h4 lights which is just one bulb that acts as the high and low. The 04-05's have separate high and lows. I believe you have to wire the harness slightly different to keep the high beam symbol from coming on.
I think gearbox wrote a diy on this. You should PM him.
Old Jul 14, 2008
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
you have the hi and low beam wires backwards switch them and you should be good
heres what i mean:
i think i drew it correctly
Old Jul 14, 2008
minorc's Avatar
Is that diagram go for both sides ? And in my kit there is a black wire and 2 red wires... anyone elses kit wired like that. The kit i have is Beamers HID h4-6000k
Old Jul 14, 2008
minorc's Avatar
With the lo-beams on the HID's are completely fine, when i switch to Hi-beam they are the exact same light but often one flickers out. I don't know if that helps
Old Jul 14, 2008
it looks as if u are not using a proper hid wiring harness? is ur ballast directly hooked up to the +/- socket of ur headlight...
ballast will flicker due the fact taht they are not getting enough power from the punie 22awg wire
Old Aug 16, 2008
minorc's Avatar
So here's all the info: I have the HID's hooked up and working fine EXCEPT, my dash HI-beam icon is on all the time with the lights turned on at the regular LO-beam setting, when i switch to HI-beam they work for a few seconds then one shuts off or sometimes both shut off. I removed the DRL fuses as i was told to from this site saying the HID's will not work unless thats removed. The only things i would like to know are: Should my Hi-beam icon be on ALL the time like it is? I have no drl's because of removing the fuse so the little peanut bulbs attatched do absolutely nothing, and should they turn off like that in HI-beam mode. Also when i turn my lights on i have to turn them on and off a few times for them to be brightest sometimes they are dim. I dont' think im drainng too much power from my headunit or my 1 10" subwoofer, anyone like to give some insight?
Thanks very much for previous posts.
Old Feb 21, 2009
BrianE.Spillner's Avatar
BrianE.Spillner is an unknown quantity at this point
I'm having this EXACT same problem on my '03 Si. Any help would be greatly appreciated!
Old Feb 21, 2009
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
^lol @name
Old Feb 21, 2009
What can I say? I like the tuna here.
Old Feb 22, 2009
^LOL @noob "tawk"
Old Feb 22, 2009
I seriously do need help with this problem though. lol
Old Feb 22, 2009
MidnightCivic's Avatar
heres what i mean:
this fixes the problem i had the same issue when i installed mine
Old Feb 22, 2009
Now do I flip those connectors on the aftermarket harness or the female factory harness?
Old Feb 22, 2009
i would do it on the aftermarket harness. in case you go back to stock and need the factory connector working properly.
Old Feb 22, 2009
Well I tried that and it didn't fix anything. The headlights didn't even come on at all. Right now I've got the low beams on and the only thing thats really bothering me is the high beam dash light is on (very dim).
Old Feb 22, 2009
okay well try the stock harness plug then. it should open up and the metal spades come out if you find that metal tab inside and push it flat with a small screwdriver. then bend the tab again before pushing it into the new spot so it clicks into place.
Old Feb 23, 2009
For some reason flipping either doesn't do anything to the high beam dimness on the dash or the lights won't come on.
Old Feb 23, 2009
roll_outz's Avatar
roll_outz is an unknown quantity at this point
just get somebody to do it for let say a PRO installer..that will do all your PROBLEm...
Old Apr 24, 2010
KOTULCN's Avatar
KOTULCN is an unknown quantity at this point
Sorry for bumping an old thread but did anyone ever figure out how to fix this issue?
Old Jun 11, 2010
Civic23drifter's Avatar
Civic23drifter is an unknown quantity at this point
I checked out many of topics on HID kits problems and decided to ask my own question, i have and HID kits for a 2003 civic coupe and i have tried numerous different wiring combinations and have came up with 2 solutions that actually work . When i turn on my lo-beams, the dash shows the high beam symbol but when i turn my hi-beams on it lights up brighter and the lights stay the same. I thought this kit had a different light for Hi and Lo beam, which is why there is a peanut bulb attatched to the light. Is this the proper way to install this kit or is my car going to catch fire in the next couple of days?
I think you installed them incorrectly because it's supposed to do that. How did you set it up?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Solo Flow
Oct 4, 2015 07:52 AM
raymondxcho
Sep 29, 2015 09:00 PM
Luluharp
Sep 27, 2015 11:56 AM
