Speedometer Recalibration
Rough, Tough, Real Stuff.
So after numerous IC modifications and some slightly-nonstock tires, my speedometer is inaccurate. But it's not a linear difference, it's about 10%. Meaning, when it's indicating 80 mph, I'm going about 72 mph. I know some of you just deal with it, but I don't like guessing how fast I'm going. The difference gets pretty big when you get up in the numbers.
I know it's possible with OBD-II cars. Anyone know the specifics?
Re: Speedometer Recalibration
Its cheaper to buy a TomTom (which tells you how fast you're going) and stick it on your dash than it is to try and have the gauge recalibrated. Rumor has it its many hundred dollars to have it done.
It's just I know for S2K's there's a "yellow box" that you can wire in that costs about $50 thats a hodgepodge of potentiometers and whatnot that lets you calibrate the speedo yourself.
blk/yel is ignition power
blk is ground
There's also a two-wire speed sensor @ each wheel for the ABS system.
Crazygrlinak
Oct 8, 2015 05:06 PM
Hutch1051
Sep 29, 2015 09:20 AM
260000milesgoal
Sep 25, 2015 07:41 PM
jerry38
Sep 20, 2015 08:38 AM
MamaBear2015
Sep 15, 2015 09:35 PM
1999, 2001, 21, 97, 98, calibration, civic, crv, honda, recalibrate, recalibrating, recalibration, si, speedo, speedometer, speeedometer
