capacitor
Old Dec 26, 2007
burtonzt's Avatar
burtonzt is an unknown quantity at this point
capacitor
i have a performance tek 1200 amp pushing a fosgate t1 12" dual 4ohms with a 1.5farad capacitor and after having my music on for a while my amp turns off
i need your opinions...should i get a bigger cap like 10farad or get an yellow top optima battery?...my friend said i should get a bigger cap
Old Dec 26, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
Re: capacitor
bigger cap wont do anything for you. it just stores power from the batter for bigger bass hits. if your battery/alternator cant keep up their useless.
Check your ground and all your connections. Make sure their secure!
Your amp might be going into protect mode from clipping or lower voltage.
You could always get a HO alternator or try getting a dry cell.
Old Dec 27, 2007
electric130's Avatar
Re: capacitor
your amp is more likely shutting down due to a problem, not lack of power and therefore, a bigger cap won't help as stated. "performance tek 1200" doesn't give any good results on google, so without knowing the specs of your amp, i can't help you troubleshoot any further. how hot is the amp when it shuts down? it may be going into thermal protection mode.
Old Dec 27, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: capacitor
My amps shut down sometimes during the summer so my first thought would be thermal. Also since I tuned the two amps and evened out the sound it doesn't seem to do that as much....in fact it hasn't at all in quite a while. Try turning the gain down on the amp. Also make sure that your box isn't sliding all over the trunk. You don't want those wires getting tugged on constantly.
Old Dec 27, 2007
ryox82's Avatar
Re: capacitor
Oh yeah, and welcome to the forums. Hope we can help out.
Old Dec 27, 2007
phuviano's Avatar
Slowest 7thgen in the GTA
Re: capacitor
Something you should have thought about before the install. I know I had my wires kept a bit longer so the box could move. Other than that, screw the box down. That would stop it from moving.
Old Dec 27, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: capacitor
caps aren't worth it at all. don't bother buying one. what you need to do is "the big three" upgrade. by that i mean upgrade the positive wire from your battery to your alternator, battery to chassis ground, and engine to chassis ground. a HO alternator wouldn't hurt, neither would a good battery.
Old Dec 27, 2007
ryox82's Avatar
Re: capacitor
yup, I have that coming to me in the mail...having electric130 do it for me, didn't feel like making them.
Old Dec 27, 2007
ryox82's Avatar
Re: capacitor
That is what I did on mine. The wires were longer on mine too but a couple airborn launches inside the trunk and the power wire came out. A couple l brackets and 5 minutes saves that problem
Old Dec 27, 2007
Re: capacitor
yep. i got them done today. sorry for the delay. been kind of crazy getting back in the swing of things with work after the holidays.
Old Dec 27, 2007
ryox82's Avatar
Re: capacitor
lol that is fine bro, I ordered 2 GB of ram for my macbook yesterday with 3 day shipping from newegg and that **** isn't getting here until the 2nd. Everything is getting delayed it seems still.
nguyen949
Oct 2, 2003 02:26 AM
kalipnoi
Aug 31, 2003 12:45 AM
jkim1978
Aug 29, 2003 09:17 PM
Civic2001LX
Apr 27, 2003 11:42 PM
noahnoah
24
Jul 21, 2002 06:47 AM
