constant 12v wire doesn't have power
Old Nov 15, 2007
jahoshok's Avatar
jahoshok is an unknown quantity at this point
Question constant 12v wire doesn't have power
I just got an '01 Civic LX, and I am trying to install a new head unit in it, but the wire that's supposed to have constant 12v, doesn't. So the only way it works right now is if I power it all off of the switched 12v, and that sucks, cuz it resets when I turn the ignition off. HELP!!!
Old Nov 15, 2007
armieo's Avatar
< My future wife.
Re: constant 12v wire doesn't have power
really? I think my 03 does the same thing. I thought that was normal.
Old Nov 15, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Check the Back Up fuse in the underhood fusebox.
Old Nov 15, 2007
spoonEM's Avatar
omgwtfbbq mod.
Like christmaspie said...its your fuse. Replace it and youll be back in business.
Old Nov 16, 2007
or just run a thicker hardwire from the battery. will make the deck work better anyway cause it gets more power. stock wires are tiny.
Old Nov 16, 2007
electric130's Avatar
um....no it's not.
Old Nov 16, 2007
Alpha 5's Avatar
Like electric said it is not normal, If you radio resets when you turn off the ignition, you either have it hooked up wrong or the fuse is cooked. Remember there are two fuse boxes. So check them both.
To the OP:
Here is the 2002 diagram:
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
| LOCK MOTOR|yellow/black | |back of the fusebox *3 |
| UNLOCK MOTOR|yellow/green | |back of the fusebox *3 |
| DISARM DEFEAT|yellow | |back of the fusebox *3 |
| PARKING LIGHTS +|red/black | |back of the fusebox |
| PARKING LIGHTS -|blue | |factory alarm plug *1 |
| HEADLIGHTS|blue/red |- |headlight switch |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| TACHOMETER|blue | |test connector *4 |
| SPEED SENSE|white/green | |PCM *5 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| WIPERS|blue (L), blu/yel(H)|- |steering column |
| LF WINDOW UP/DN|red/blk - red/yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |drivers kick panel |
| LR WINDOW UP/DN|brn/wht - brown |A |drivers kick panel |
| RR WINDOW UP/DN|blu/org - brn/yel |A |drivers kick panel |
| RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
Notes:
NOTE: This vehicle has an immobilizer system *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
4 banger
Jun 5, 2015 01:44 AM
darwin-t
Apr 18, 2015 09:29 PM
NukeSilo
Nov 20, 2001 05:17 PM
