Need More Juice???
Old Nov 6, 2007
pnoyster2k1cvic's Avatar
Balut Eating Champ
Need More Juice???
ok, i travel alot and i run my laptop using a cigarette lighter plug converter 100w and i'm charging my phone at the same time and i notice the light on the plugs looks like it's deeming... am i sucking more power than my alternator can put out? <<< no green jokes please :P
so here's just an example, i'm not electrically inclined <<<
so EXAMPLE
headlights = 100w???
amp/subs = 75w
laptop = 90w
cellphone =10w
275watts? how much wattage does OEM alternator put out? do i need a bigger one? what brand? where? how much? thanks for the help guys!!!
Old Nov 6, 2007
greeen01civic4d's Avatar
Re: Need More Juice???
put simply, u need a high output alternator, about 250 bucks at a local stereo shop or online, its easy, but the only way to get enough power to run all that stuff
Old Nov 6, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
its by AMPERS not Wattage.
Old Nov 6, 2007
armieo's Avatar
< My future wife.
just wondering.... where the hell have you been pnoyster?
Old Nov 6, 2007
spoonEM's Avatar
omgwtfbbq mod.
Youll be happier if you get a high output alternator. I ended up destroying mine, and I put a high output in and no I have no worries. haha. The alternator is a total pain to change. lol. Not hard, just time consuming.
Old Nov 7, 2007
Balut Eating Champ
i went to Iraq for my second deployment for 16months i just got back last month... so i've been traveling alot spending all the cash i saved ... i'm gettin' an STi this month i thought i'd throw it out here
so ok, it's amperage and NOT wattage... ok so any ideal numbers here? how much OUTPUT am I looking at when buying an alternator? how much AMPERS do I have on my OEM ALTERNATOR?
thanks for the help guys...
Old Nov 7, 2007
FGCOUPE's Avatar
i think on the 2001 altenators are mitsubishi?
as far as a better one in amperage, this im not sure?
Old Nov 10, 2007
mneuls's Avatar
mneuls will become famous soon enoughmneuls will become famous soon enough
your wattage for your subs seem a little low, but the equation for calculating amperage from watts is P=IxE where P is your wattage, I is amperage and E is voltage. if you rearrange it to P/E=I you get 275W/12V=22A
a stock alternator puts out between 65 and 75 amps you should be good,
but, like I said, your sub/amp seems a little low.
you should be able to run a 600W system with no problem at all, and a 1000W system with some minor dimming of the headlights, it is when you get past 1500W I have found that stuff seems to not work properly.
If your wattage is what you say, you won't need a better alternator, you might want to look into getting a better inverter, hardwiring one would be the best way to go.
Old Nov 10, 2007
Balut Eating Champ
the wattage on my amp is not accurate it was just a GUESS-TIMATE... i have rockfords pushing 1200watts and yes the lights are dimming and when i plug in my laptop then it gets even worse on idle, but when i'm running 2500 and up RPM seems fine... but i have extra cash to buy me an alternator that put out a bit more...
so ok, my target amperage should be around 100+amps then? ok cool... thanks for the help guys...
pilebuck13
Sep 21, 2015 10:45 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Klame9420
Sep 7, 2015 10:03 PM
alinaray
18
Aug 24, 2015 01:04 PM
