rear licence plate.....RATTLES
Old Mar 30, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
i see that the rear licence plate is where most of the rattling is comming from but it's because there are
no damn holes at the bottom screws to bolt it on tight anybody know how i can get this licence plate down
without drilling extra holes into the damn car
instead of having screws i see two rectangular foam peices i guess to stop it from hitting the car ....
how did yall get your plates to stay on tight when u didn't have holes in tha trunk for a screw?
Old Mar 30, 2002
Edna's Avatar
Edna is an unknown quantity at this point
there are a lot of ways to fix that common problem, the easiest would probably be to stick somethign behind the liscence plate, like one of those sticky cork things that go on cabinets, so when the plate hits the car, it doens't make any noise.
-Edna
Old Mar 30, 2002
mohawkboom's Avatar
yup.. tighten the bolts and put some sticky foam or even 2 sided foam carpet tape on the back [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 30, 2002
HeRbaLuS's Avatar
hmm so 2 way tape should do tha job eh......
k imma get some a try it out ........i wonder if those foam stoppers that are there from factory are gonna make any mess
Old Mar 30, 2002
mohawkboom's Avatar
the foam stoppers should be doing the trick.. Now are you postive it's the plate itself that's rattling or is it the trunk latch?
Old Mar 30, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
I have the same problem but it is coming from the plastic trim from the dealer hitting the plate. I think that is the only rattling I am hearign right now, but I will have to wait and see since I have only had my subs in for about 5 days now.
Old Mar 31, 2002
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
i used sponge for the same problem. but then another problem came from it. when i washed my car, the sponge would soak up water. so when i'll be driving around, water would drip from it and i'd have UGLY water streaks goin down my trunk so i just took em out, and im going to replace them with one of those rubber stopper thingys.
Old Mar 31, 2002
WhiteRabbit's Avatar
rubber weather stripping. works great, used a #$(* load cause i had it on hand
Old Apr 1, 2002
SneakyPeak78's Avatar
SneakyPeak78 is an unknown quantity at this point
use dynamat, water doesnt effect it.
Old Apr 2, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
double sided tape! [IMG]i/expressions/beer_yum.gif[/IMG]
Old Apr 3, 2002
fourkilos's Avatar
fourkilos is an unknown quantity at this point
i used common sense
Old Apr 3, 2002
Bdubb's Avatar
Bdubb is an unknown quantity at this point
Dynamat has a license plate cutout you can buy for like 15 bucks just attatch it to the back and happy thumping
Old May 2, 2002
WaffL3S's Avatar
WaffL3S is an unknown quantity at this point
i have the same prob.. i bought a velcro tape and put the softer side 1 for each corner jst cost me less than 5
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
czarlun
Sep 14, 2015 08:16 PM
Stock 99
Sep 5, 2015 06:06 AM
