01 Radio Replacement
Old Sep 10, 2007
Mike799's Avatar
Mike799 is an unknown quantity at this point
I just purchased an 01 that has the keyless entry system and want to replace the factory radio with an aftermarket one. I saw something that said that the keyless entry would not work without the factory radio. Is this true? Is there any way around this? Any help would be appreciated! Thanks.
Old Sep 11, 2007
CraigW's Avatar
Re: 01 Radio Replacement
That occurs on earlier generations.
01-05s use a different system.
Make sure to get a wiring harness adaptor from Metra or similar company, makes the install easier.
Old Sep 11, 2007
Mike799's Avatar
Great news! I already have the harness from Metra and attached it to the new radio. Should be ready to plug and play. Thanks again!
Old Oct 7, 2007
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
my keyless still works. should be fine.
trellex
May 24, 2015 04:39 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
thesushiboy
Apr 12, 2015 02:54 AM
Perfectcivic
Jan 23, 2002 07:39 PM
