DEI Hornet Install Help
Old Oct 2, 2006
shifoe's Avatar
shifoe is an unknown quantity at this point
So I tried installing this system today and it wen pretty bad. My gauges don't work at all now. I tried cutting the oem security system harness and splicing the corresponding wires. I had it working somewhat and now am scared to go any further.
I have looked everywhere for some definitive info and can't find anything. I'm going to check the 7thgen manual. Any ideas?
Old Oct 2, 2006
4Saris's Avatar
4Saris is an unknown quantity at this point
The key to a good alarm is the install, looks like you are screwed on that one. Installing an alarm is generally not a DIY unless you have experienced guidance. You are lucky that you didn't trigger an airbag like some dude did at my old audio shop in high school.
As for help, your best bet is to PM christmaspie
Old Oct 3, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Here's the wiring diagram for the security connecter. I also sent you a PM with a wire by wire break down of each wire's function. Get those pics to me and check that fuse in your underdash fuse box. Fuse #10, 7.5A
Reference the attached documents.
Old Oct 4, 2006
4Saris's Avatar
All you are missing is...
"Do or do not, there is no try."
Old Oct 5, 2006
shifoe's Avatar
That was it. Both diagrams saved me! Thanks chrismaspie. Must have blown the fuse when I was making the wrong connection to my security harness. All is well now and the security is working well.
125 bucks for power door locks and security is awesome too
If anyone is interested in a DIY for this let me know, I can write one up. Aftermarket alarm is much cheaper than honda OEM one, but install isn't plugnplay like OEM
Old Oct 9, 2007
Oppjonez's Avatar
Oppjonez is an unknown quantity at this point
Re: DEI Hornet Install Help
A DIY on a alarm would be great. I have not done an alarm in like 6 years. I am a little rusty. I could use tips and some help.
Thanks Man
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
