2002 Civic - won't start
Old Aug 18, 2007
sitheref2409's Avatar
sitheref2409 is an unknown quantity at this point
Car was going through a funny electrical phase.
If I had the radio on, air con running, and then added something else to the electrical mix (rear window heater, braking...), the the radio would dim, the ABS warning light would come on.
Switched car off. Turned key.
Fast "clicking" noise - but it wouldn't start. When I turn the key, I can get all the usual warning lights; the radio shows "CODE" - but it won't start, and it clicks.
When I bring the clutch up, then the clicking goes away, but the engine still won't start.
I think it could be:
Battery - enough to give me electrics, but not to start.
Fuse - given the "weirdness" I was having earlier
Starter.
Any ideas? Help!!
Last edited by sitheref2409; Aug 18, 2007 at 04:56 PM. Reason: Because I can't spell
Old Aug 18, 2007
speedfoos's Avatar
Re: 2002 Civic - won't start
Sounds like your alternator is not giving out enough juice to power everything you have running.. Subsequently it drains the battery which leads to the clicking noise you're hearing, which would mean your alternator is probably about to, or already has, die. Your car has a little voltage sensor, and if the battery voltage is too low, it won't try to turn over the starter, and you'll just hear the clicking sound. Get it over to Autozone and have them test it and the battery for starters.
Old Aug 20, 2007
electric130's Avatar
... Get it over to Autozone and have them test it and the battery for starters.
yep and yep. they'll do the test for free.
Old Aug 22, 2007
mneuls's Avatar
mneuls will become famous soon enoughmneuls will become famous soon enough
halliluyah, say it loud Buddy Christ.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
