fog light wiring please help (did search)
Old Jul 8, 2007
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i bought ebay foglights. please help....my kit has different plugs then those on the links i found
ok guys i did the search...i even got 5 links bookmarked...still cant put it together
1) where does the harness plug into the car???(1st & 2nd picture)
2) there s an extra plug on the subframe harness (1st picture)
**** MAX PICTURE FOR CLEARER LOOK****
extra picture showing relay box / ground / switch
so i had most of the wires routed...but decided to take them out to take a picture of all wires
Old Jul 9, 2007
electric130's Avatar
Re: fog light wiring please help (did search)
i'm going to leave this open for now, but for future reference, make just one thread with all your problems instead of spreading them all over the board in different threads. you have fog light problems, that's one thread (regardless of how many associated problems.) you have engine problems, that's another thread.
since you said you have 5 bookmarks, post the links and we'll see what you've researched and try to figure it out.
Old Jul 13, 2007
PopcornPlaya's Avatar
Electric Boogaloo...
https://www.civicforums.com/forums/2...-issues-2.html
That should answer it, and it was on the front page of ICE.
https://www.civicforums.com/forums/s...archid=1231910 Try that search as well. The answer is in several of the threads. A helpful hint when searching:
Use Quotes: EXAMPLE: "fog light wiring"
To get even better results add periods and remove spaces: "fog.light.wiring"
Hopefully this helps in future searching as well as answering your question.
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
