Compustar alarm hood pin problem...
Old May 20, 2007
kornsined's Avatar
Every time it rains the damn hood pin sets off the alarm. Anyone else have this problem? Remedies to fix it?
I'm thinking maybe it needs to be placed somewhere else under the hood where it won't get wet.
Old May 20, 2007
Re: Compustar alarm hood pin problem...
lol i had so much trouble with that i ripped it out. if theyre gonna be getting the hood open, the shock sensor will have already triggered the alarm anyway.
Old May 20, 2007
kornsined's Avatar
yeah this thing has been virtually useless.
Old May 20, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Go with a tilt or mercury sensor attached to the underside of the hood. Works like a charm.
Old May 20, 2007
snobird's Avatar
snobird is an unknown quantity at this point
i dont see how the hood pin will be setting it off a hood pin has plastice parts with a metal tip and once the two metal parts make contact it goes off i have trunk pin and hood pin no problems for me
when it rains my alarm goes off to since i have the shock sensor set all the way up maybe turn your shock sensor down
Old May 20, 2007
but really why does it matter, if they somehow get in the car without setting off the shock sensor, just pulling the hood release will set it off for sure, or if they pry the hood open, same thing. its useless to have a hood sensor. i have my shock sensor way down tho too i hate false alarms. even bass and thunder dont set it off but banging the door still does which is all i want.
Old May 20, 2007
snobird's Avatar
well its good to have them cause people can get your trunk or hood open without setting of shock sensor if they know what they are doing. its just one more layer of secuirty
Old May 20, 2007
Also they're nice for remote start shutdown, not sure if that even applies to the original poster.
Old May 20, 2007
kornsined's Avatar
yeah my remote start won't work if it's set off. My shock sensor is set really low. I know it's the pin because every time I reconnect it the problem occurs.
Old May 20, 2007
snobird's Avatar
probally somehting worng in the pin cause u have a metal clip at bottom with a wire that has a current then plastic shaft then the bolt is metal when the metal contacts each other it triggers alarm so either try new pin or differnt location but water shouldt be affecting it
Old Nov 24, 2009
davidmharris's Avatar
davidmharris is an unknown quantity at this point
I have a question about the hood pin as well...if i arm my car and pop my hood the pin doesn't sound the alarm. i don't feel like replacing it and just want to remove it. can i just cut the wire and leave it at that or is there more i have to do for any reason will it draw off the battery at all?
Old Nov 24, 2009
nope just cut the wire. i took mine off too when it broke.
Old Nov 24, 2009
Thanks
Old Nov 24, 2009
i would put some tape on the end of the cut wire too just to be sure it doesnt touch anything.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
frank_kleng
Sep 29, 2015 10:55 PM
Bruce2
Sep 27, 2015 08:45 PM
First Car
Sep 8, 2015 08:54 PM
