speaker problems
Old Mar 15, 2007
yingjai's Avatar
yingjai is an unknown quantity at this point
speaker problems
my front left speaker doesnt work. i bought a pair of oem from a 1.6 el and they were crappier than my civic's.
i just want to know what could be the problem and if it's fixable. i don't see any tears, so it's not blown.. the wires seem to be connected.. what else could be the problem?
Old Mar 15, 2007
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Just because it doesn't have any physical damage doesn't mean that the speaker isn't damaged. There are a lot of sensitive parts to a speaker (voice coil, connections,) that could have been easily damaged by the previous owner. Try to avoid purchasing used audio equipment! Aftermarket is the way to go!
Old Mar 15, 2007
yingjai's Avatar
my first post might be misleading.. but i am trying to fix my oem civic speakers.. that is the reason why i bought used oem 1.6 el speakers.. but then i found out they were crappier than my civic's , so i just want to fix my oem one instead of installing the 1.6 el.
Old Mar 15, 2007
Taffy's Avatar
So you did all that work taking the door panel off just to try to fix the crappy paper cone OEM speaker? Do yourself a favor and buy some good aftermarket 6.5's. Any brand will do, as long as it is not OEM. An aftermarket speaker has a stiffer cone, larger magnet and dome tweeter to produce a fuller sound. It doesn't even have to be a brand name, anything is better than OEM. Think about it, they put those OEM pieces of crap in there to satisfy the needs of old grannies who drive 5 minutes to church. Do not tell me that you are content with that! Take your behind to the nearest audio shop and get some nice aftermarket speakers ASAP!
Old Mar 15, 2007
electric130's Avatar
swap left and right and see if the problem switches. if it does, you've got a bad speaker. if the same side is bad, it's wiring in your car.
Old Mar 15, 2007
yingjai's Avatar
It's definately not wiring of car. I plugged the 1.6 EL in and they work. No way I'm going through the trouble taking off 2 door panels.
But yeah... I've decided to go for a pair of used Alpine Type Rs. They would still sound better than OEMs without an amp right?
Old Mar 15, 2007
mikenam's Avatar
mikenam is an unknown quantity at this point
alpine type r prolly won't fit w/o buying a kick panel. magnet is huge.
Old Mar 15, 2007
yingjai's Avatar
ew.. what other components are available that fits without kick panel? i want an oem feel.
Old Mar 15, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
infinity refernece 60101101 w/e... the infinity ones
what spacer would they require?
Old Mar 15, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
i went with some pioneer 6.5's. they sound good, cost 50 bucks and fit.
Old Mar 15, 2007
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
^^^I did the same and they sound pretty good, stock speakers are a joke.
Old Mar 15, 2007
yingjai's Avatar
spacer? i dont have a good technical know-how lol.
Old Mar 15, 2007
yep, they won't fit. i already tried
Old Mar 15, 2007
3/4" would work
Old Mar 15, 2007
click the link in my sig. it's also a sticky.
Old Mar 15, 2007
yingjai's Avatar
I've already seen that howto lol. I used it to take off my door panel. I asked about spacer cause someone was asking and I said I don't know.
also... what's the size for the rear speakers? i'll probably replace the whole car with pioneer g series temporarily until i am rich enough for a good A/V system in my car.
just to be sure.. the g series ARE better than Honda OEM components right? I have the top model of 2004, so I'm not talking about Civics without door sail tweeters. my friend was amazed at the quality of the cone material.. they're not like construction paper type
Old Mar 16, 2007
TRIZ's Avatar
Your friend is probably.. well, i'll be nice.
dude, head here... www.crutchfield.com and fill out the specs on your car to see what will fit.
As was said, dont buy used audio equiptment... thats just retarted. Speakers have a life... dont adopt an adult.
Old Mar 16, 2007
Old Mar 16, 2007
mikenam's Avatar
if you are not running an amp or at least an aftermarket Hu then get cheap aftermarket speakers. Itll be a waste.
Old Mar 16, 2007
yingjai's Avatar
I have an Alpine h/u. Plus I got Boston Acoustics S65RC for front and S95? for rear instead of the Pioneer G series. Got them from Ralph Audio. They gave me a great discount... or so they say.
Old Mar 16, 2007
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
you can buy my infinity's. 50 bucks. 6012i's, I believe.
Old Mar 16, 2007
yingjai's Avatar
well i already bought brand new.. even though they're coaxials and not components.
dbagaus
Jun 10, 2015 09:29 AM
SLeePeR012
Jan 7, 2002 12:24 AM
guy
Jan 6, 2002 04:39 PM
djaber
Jan 4, 2002 06:23 PM
PimpBot5000
Nov 26, 2001 07:15 PM
