VAFCII/A/F gauge
Old Mar 14, 2007
hwt101's Avatar
hwt101 is an unknown quantity at this point
VAFCII/A/F gauge
Well i got both hooked up and prior to me changing any settings the car runs RICH until idle then it runs LEAN, anybody wnat to throw in their 2 pennies
Old Mar 14, 2007
ronaldo9's Avatar
Normally on honda engines you will run lean at idle bc there really is no need for that much fuel since there's no load and it will run rich inthe upper rpms to compensate for the VTEC. What do you mean be rich and lean what are your wideband readings?
Old Mar 15, 2007
hwt101's Avatar
i dont have a wide band hooked up just the autometer a/f gauge that i picked up and its pegged out on the rich when i get on it, as soon as i get my header hooked up im going to take my car to stoopidfast here in town and get it dyno tuned
Old Mar 15, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
that a/f gauge built in the vafc is not accurate. it gives a good idea of when your rich and lean but nothing more. the only concern you should have with that gauge is if it says lean at WOT.
Old Mar 15, 2007
hwt101's Avatar
its not the built in a/f meter its an autometer phantom series A/F gauge
Old Mar 15, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
thos readings on a "NON WIDEBAND" A/F gague is crap.
them mean nothing.
go get a wideband a/f gauge and those are the "true" A/F readings
good luck!
Old Mar 15, 2007
hwt101's Avatar
hmmm, guess ill have to check into that
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
