turn signal bulb for proejector
Old Mar 9, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
i bought a pair of projectors off of ebay. I was wondering what size turn signal bulb will fit in the hole?
Thats a picture of the projectors I had. The stock connector wouldnt fit in the hole right so i used the 1156 adaptor that they gave me which fit perfectly. So i wired this harness to work with the turn signal. its only comes on when i signal and not with the parking lights. so i bought an led bulb from autozone and it was too big to fit in the opening. So does anyone know of what size bulb or bulb to get preferably LED that will fit in the opening.
Old Apr 3, 2007
Re: turn signal bulb for proejector
its supposed to fit the stock 7443 bulb socket. even says on the back. the 1156 they give is not right and it only has single filament. use the stock plug and silicone it to the housing so its not loose. it will go in but its just a bit loose.
Old Apr 12, 2007
0H3ebpEM2's Avatar
alright thanks gear. so any 7443 led bulb will fit then? i was either thinking an orange color or a yellow
Old Apr 12, 2007
ya you use the stock turn socket so any 7443 bulb base will fit it
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
Blv
Jan 5, 2002 11:06 PM
Dagooseisloose
Nov 9, 2001 10:18 AM
