Coupe rear turning signal bulb
Rep Power: 0 Coupe turning signal bulb
I noticed that the bulb chart in DIY section is for the Sedan, and for the Coupe the rear turning signal bulb number is 3156. Does anyone know where can I get the amber-colored replacement for this bulb (tried Pep-Boys and Autodynamics.com, don't have any, will 3157 fit (it's double coiled though)
Rep Power: 0 i've called a few pep boys around here and they're not ordering the amber led's, but if you were to go to some custom shops, they carry them, or can order them for you. when i called pep boys they said they run about 17-20 bucks a piece, and you need 4 of them.
Retired suspension supermod.
Rep Power: 387 I looked around for an amber bulb. The number is also 7443 i think. It is a bigger one than the parking light. You might have to order it seperately from somewhere. I found some on Yahoo. . I had a hard time finding one in the store. Good luck
Rep Power: 0 7443, they are the same ones as the ones that turn on in your tailights. Not the brake lights but the rear lights that turn on when u flick the switch on[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
