PLEASE HELP!!! subwoofer makes weird sound
i just installed a pioneer mono amp 360 RMS with 2 12" subs at 150 RMS each, and at first they sounded ok, but the next day, the subs would make a weird "thump" sound each time i change the track on a cd or a new radio station. any1 know what the problem could be??
actually i got a clarion head unit to go with it, but yeah , my ground wire from my amp to the back might be wrong i don't know, because i bolted it to a screw on the underside of the rear deck , which i ain't sure is metal because it doesn't feel like it...
yeah, find some bare metal on the chassis and bolt the amp ground to that. take some sandpaper and sand off a small patch of paint if needed. just make sure you get bare metal.
dremel
own a dremel? use the wire coil or i forget what its called but in the trunk like the bar behind the back seat just dremel a small part of paint away from there, and then drill and ground. thats what i did.. all better. or just find another location.. CAREFUL: Sparks fly
yeah , it probably is the ground wire from the amp, i grounded the ground wire to the under part of the rear deck which is probably like some sort of plastic , not metal, but yeah thanks for all the help guys =]
mrohitredd
18
May 14, 2015 07:35 PM
SSMatey
Apr 13, 2015 06:09 PM
Ronin
Nov 17, 2001 09:46 PM
