for the blueish headlights...
Old Nov 29, 2006
mattyg23's Avatar
mattyg23 has a spectacular aura aboutmattyg23 has a spectacular aura aboutmattyg23 has a spectacular aura about
if i want to acheive a blueish effect on my headlights, like the newer cars have, how would i do it, do i need all new headlights or just bulbs? sorry for the noob question
thanks
Old Nov 29, 2006
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
Search for Hid's
Old Nov 29, 2006
spoonEM's Avatar
omgwtfbbq mod.
HID's. 8000k. I have a Mcculoch 8000k and love them. Had them for well over a year now with no problems.
Old Nov 29, 2006
lxcivic2k1's Avatar
I just bought some Cool Blue Phillips bulbs. There not really blue just a LOT whiter than stock lights. I got them cause I didn't want to put some money into HIDs since the bulbs were only $20 vs $375 for HIDs.
Old Nov 29, 2006
mattyg23's Avatar
how easy are the hids to install?
Old Nov 29, 2006
for h1 bulbs (i.e. most projectors), you have to bore out the hole where the bulb goes a little..
Old Nov 29, 2006
TRIZ's Avatar
you dont need HID's, its just bulbs... there are a bunch of articles on how to instal HID's allready on this site.
From everything i've read, its pretty easy- do above if needed and just find a place to put the ballasts. Depends on what leadlights your putting the HID's in though. If your triyng for the OEM or TYC, there are articles on here... here is another thread with a decent wire diagram.
http://www.7thgencivic.com/forums/sh...hlight=HID+DIY
^ this is for adding a relay, but type HID wiring diagram into google and you'll get more info then you can handle.
also, www.hidplanet.com is a great place to find many answers- these people know tons.
Old Nov 29, 2006
TRIZ's Avatar
here is a link to a retrofit if you want to go that route with the TYC's
http://retrofit1.dirtysamurai.com/
Old Nov 29, 2006
burke420's Avatar
The World Is Yours!
ive ordered some 12000k mccullloch bulb for my kit... i want a more exotic look... ill show some pics son..
Old Nov 30, 2006
A03's Avatar
A03
A03 is an unknown quantity at this point
For an exotic look and top notch performance, get Acura TL projectors with ZKW (new 3 series) lenses swapped in. It is one of the most killer combos out there IMO. Excellent brightness, width and TONS of colors in the cutoff.
That is exotic...
12000k plug-in HID bulbs IMO = rice.
Exotic does cost money.
Old Nov 30, 2006
spoonEM's Avatar
omgwtfbbq mod.
HIDs are not rice. Blue halogen bulbs are rice. Just thought Id clear that up.
...and not everyone has $1000+ for lights. We were just giving him ideas that were a little more affordable, even thought HID plug and play kits arent exactly cheap either. After getting everything retrofitted in your car, that setup would be rediculously expensive.
Old Nov 30, 2006
spoonEM's Avatar
omgwtfbbq mod.
...and nothing beats the s2k retro.
Old Nov 30, 2006
ragingSPAM's Avatar
I just burnt my tongue
lexus ls430 does with tsx lenses...only projector retro i would take over the s2k...anyways...800k is way to blue of light...the color oem cars use like bmw, lexus, mercedes, infiniti, etc is 4300k which is oem color temperature of hid lights
Old Nov 30, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
thanks
are you referring to the blue that you see on BMW's?? If so, its not as simple as a light bulb.
Its the actual reflector in the headlight housing, because all OEM HID kits come with 4100K bulbs which do not produce blue light. To acheive that blue light look like BMW's, you need the hid headlight housing from a BMW. Otherwise you'll never achieve that blue tinge.
If your not referring to the blue that you see on BMW's, you can produce blue light with 6000k hid kits or higher.
Old Nov 30, 2006
ragingSPAM's Avatar
all bmw's use hid projectors if they are equiped with an hid option...mercedes has used reflectors previously but now are all oem projectors...from a reflector or projector from a distance all hid lighting will have a blueish aura around it but sometimes you wont be able to see it because of the blue or purple color of light...
Old Nov 30, 2006
A03's Avatar
A03
I don't have all the time to explain everything, but here is a start..
The fancy/flashy blues and purples you see on OEM HID equipped cars are just the colors along the top of the cutoff band. Projector headlights typically have some form of color band where the lighted area changes to dark. Some cars are yellow (like some of the Infiniti FX) and some are very colorful blues, purples and other nice looking deep colors (like S2000, TL etc).
The light that the projectors spread across the pavement is WHITE. It's white so that the driver can see the road clearly. Blue light on the ground does not help you see better, only worse (especially in rain).
So in short, the nice looking lights you see aren't really colorful lights.. it's just the attractive color band between light and dark that you see flickering at you as the OEM projector equipped vehicle is moving over bumps in the road. If your eyes catch it right between the dark and lit line, you will see the flashes of pretty colors.
Plug in HID bulbs for your stock assembly is completely inferior. Some people may think it is cool or not rice, and some people think it's a waste of money and is rice.
for lots of good info, see www.hidplanet.com also talk to Gearbox here who I know has a projector retrofit, or talk to Jay78 who has many high end HID projector parts and many retrofits done or in the works.
The output and 'look' of a projector retrofit beats a cheap HID kit implant in every category. It costs more, but it's better. End of story.
Old Nov 30, 2006
spoonEM's Avatar
omgwtfbbq mod.
....to each his own
Old Nov 30, 2006
bkidnon's Avatar
bkidnon is an unknown quantity at this point
Projector (4300K E46)
vs
Reflector ( 6000K )
and above 6000k is a no no
Old Nov 30, 2006
A03's Avatar
A03
bkindon:
Awesome example. White light on the ground, wider, sharper, all around better!!!!
THANKS!!!!
Old Nov 30, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
cool!
Old Nov 30, 2006
burke420's Avatar
The World Is Yours!
if you cant see... get fogs itll help! the hids arent the best for extreme weather. all the factory, hid equipped cars have a halogen fog or high beam to help penetrate the adverse weather out there!
ImPulse
Dec 5, 2004 09:20 PM
zen_master
Lighting
22
Aug 1, 2004 09:48 PM
StealthCivic
Lighting
Apr 13, 2004 10:26 AM
zen_master
Lighting
Mar 29, 2004 08:38 AM
iLLuMiNaTi
Aug 11, 2003 02:01 PM
