Question - Ground Loop Isolator
Old Nov 16, 2006
MBison's Avatar
MBison is just really niceMBison is just really niceMBison is just really niceMBison is just really nice
Hey guys. So I got a ground loop isolator by stinger and my question is:
do I need 2 of them if I have a 4 channel amp? if not, how do I connect the
male rca's from the SGLI to the amp? theres 2 male connectors on the SGLI and 4 female on my amp for each channel. hope to see some feedback from professionals. thanks!
Old Nov 16, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Can't rid yourself of the ground loop?? I'm not a fan of using a ground loop isolator unless you absolutely can't find a way to get rid of whatever particular noise is bothering you.
If you're using a 4 channel and not bridging it at all you'll need a second GLI. If you try to use y adaptors and one GLI you'll lose either balance or fade (assuming the amp powers your interior speakers.)
Old Nov 16, 2006
MBison's Avatar
Thank you very much! +rep
Old Nov 16, 2006
LudlamTheory's Avatar
i boogie for the raindrops
i'd highly reccomend cleaning up and or entirely moving your amp ground, redoing your headunit ground, and all that before touching a gli
they can degrade sq at times
Old Nov 17, 2006
MBison's Avatar
Ok. Wheres the best grounding point I could use for the hu and the amp? the amp is installed right by the spare tire. Thanks!
Old Nov 17, 2006
due to the nature of the automobile, there is no "best"
gotta test it out
Old Nov 17, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
What brand of amp? It has been my experience that cheaper amps are more prone to noise.
I grounded my amps via a distribution block to one of the seat belt bolts underneath the back seat. Are your power wires seperated from your speaker/RCA wires?
Old Nov 17, 2006
MBison's Avatar
I have a 1000W Profile amp. The power wire is separated from the RCA wires but its zip tied wit the speaker wires, because they were run on the same side of the car. After I've connected the SGLI to the left side speakers I can only hear the alternator noise in the right side speakers, so I figure that I need to buy another SGLI and hook it up to the right side speakers. What do u think?
Old Nov 17, 2006
dabflyboy's Avatar
dabflyboy is an unknown quantity at this point
IMHO i would have placed the power wire through the trunk, under the middle of the backseat, and straight down the tranny hump (where the console is) to avoid contact with the RCAs or speaker wiring. thats what i did in my previous truck and it worked just fine. of course i have no clue yet as to how much insulation there is on these civics since im pretty new to them (i bought my 2003 coupe only a month ago).
Old Nov 17, 2006
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I, too, ran my power cable down the middle of the car. No issues.
Old Nov 17, 2006
coop's Avatar
Profile can be classified as a "cheaper" amp - I had a Poweracoustik that had the same issues. You'll need a ground loop isolator for each pair of channels. Ludlam is 100% correct - they will help cut down the noise but they are a band aid - ideally you never need them................
Old Nov 17, 2006
MBison's Avatar
right on. i want to avoid takin my interior apart though. ive already bought 2nd Stinger GLI and that should do the work. i've noticed that there was a different kind of noise appearing when I turn my headlight switch on. its less annoying than the alternator noise but still...
Old Nov 17, 2006
Wherever you end up grounding make sure to remove all the paint so you get a good connection. I also recommend using a star washer or even better is to use a nut and bolt if you can access both sides. If you're getting multiple kinds of noise issues you really should look at upgrading grounds and moving components before you commit to two GLIs.
Old Nov 17, 2006
d17acivic's Avatar
d17acivic is an unknown quantity at this point
like everyone else has said i would stay away from GLIs if you can. i would definitely sand all the paint away wherever you decide to put your grounds and certainly play around with different metals when trying to ground.
Old Nov 17, 2006
MBison's Avatar
^thanks, guys. i will take ur advices
Sep 26, 2023 06:44 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
sch2cm
Jul 21, 2015 09:58 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
