Quick Question
Quick Question
I have a Power Acoustik deck and It has Audio outs, ones for Right Rear and Right Front and the other is for left rear and left front. So my question is how can I hook up subs if there are no sub outs? Thanks for the help
if you have no sub out, put it in the rear pre outs. it's not as good as with a sub out that you can set seperatly from the speakers, but it's the only thing you can do. a sub out is way better cause you can somethimes set your frequencies to your speakers and sub seperatly, wich is best.
So will the subs hit or will they just be like a speaker and play music?
Also I plan on running 2 amps so should I run 2 sets of RCA's , one from the Left outputs and one from the Right outputs?
alright thanks man
But still have one question
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
NoobyKid
Jul 13, 2015 07:53 AM
