bulb wiring question
Old Jun 22, 2006
i have a bulb, i want it to turn on with the parking lights, but turn off when the hi beam is activated. i have tyc headlights and for some reason, every headlight wire i hook it to makes the light stay on by itself without anything else turned on.
Old Jun 22, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
how do you have the bulb wired up?
Old Jun 22, 2006
right now just tapped to parking light power and ground. the headlight wires seem to be hot all the time.
Old Jun 22, 2006
jay78's Avatar
jay78 is on a distinguished road
steve dont u think this should be in lighting forum???
Old Jun 22, 2006
CraigW's Avatar
For the headlights + power is supplied to the common terminal of the bulbs and the high and low beam terminals are grounded through the combination light switch.
Old Jun 22, 2006
great so any ideas? i guess i'll be looking at the service book again.
Old Jun 22, 2006
CraigW's Avatar
Only off when the high beam on ?? How about with low beams on ??
Old Jun 22, 2006
only off when hi beam is on. i want them to stay on as parking lights when regular low beam is on. see its the bulb in the hi beam housing far left. i dont want it to blow when i use the hi beam cause the bulb is almost touching.
Old Jun 22, 2006
2 relays should do the trick, the first one will break the positive connection of your bulb when the high beam is activated while the second relay will complete the bulb's circuit when your low beam is on. You could do it with only one relay, but like to use factory wiring for signaling only.
85 High Beam Ground
86 +12 volts
30 +12 volts
87 Empty
87a + Bulb
85 Low Beam Ground
86 +12 volts
30 Ground
87 - Bulb
themechanic
Lighting
Feb 2, 2018 09:23 PM
Lopes101
Jun 7, 2015 08:04 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
Fastfebur
Apr 22, 2015 01:37 PM
Aznnp77
Dec 9, 2001 08:19 PM
