ground question
Old Jun 12, 2006
latts's Avatar
latts is an unknown quantity at this point
ground question
i have my positive wire with fuse run to the trunk attached to amp, remote turn on from deck to amp, ground from amp to metal in trunk.. when i connect my negative battery terminal i get a little spark.. i'm guessing my ground i did is no good? its a 2002 civic.. i tried grounding it to the metal that goes across the trunk near the seats just under the trunk carpet..
thanks
Old Jun 12, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
its normal to have little sparks when reconnecting it, it just means that there is a few things (example: Headunit memory) using power when car is off, thats why it makes a spark when you reconnect.
Old Jun 12, 2006
latts's Avatar
cool.. thanks.. works now
juror
Suspension DIY
Jul 30, 2019 03:28 AM
sch2cm
Jul 21, 2015 09:58 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
