12v accesory outlet....
Old May 30, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
is there a way to wire it so that it doesn't shut off? ya know like most new cars that have accessory outlets that don't turn off after the engine is shut off. so that you can charge your phone?
Old May 30, 2006
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Run a wire straight from the battery to you the positive side of the outlet, then a wire to ground. Make sure you put a inline fuse on there.
Old May 30, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
That would be stupid to run a wire from the battery all the way to the 12v socket when you can just cut the +12v wire off on the 12v accessory socket and tape it away. Then tap from the +12v CONSTANT on your stereo deck and run it to where the 12v ACC wire was on the 12v socket. Then you have constant 12v at the accessory socket. Now if you're going to be using ton's of stuff on that socket, ie. and inverter and stuff, then you should run a wire from the battery to the socket as you wouldn't want to overload the factory wire harness that was supposed to only be running your stereo...
Old Jun 3, 2006
Rufus's Avatar
^correct
h4ldol
Apr 24, 2017 08:16 PM
metalpres
Sep 23, 2015 05:22 AM
Donahue
Sep 9, 2015 05:55 PM
msaeger
Sep 2, 2015 08:47 AM
