New Solution to SRS Light problems
Old Jan 25, 2006
Juancho007's Avatar
Juancho007 is an unknown quantity at this point
Guys and Gals,
If you have had your ODPS unit replaced because of a code 1502 or 1503 SRS light (This is when the dealer tells you that it was caused by a laptop or some kind of electronic device on the passenger seat) and your SRS light turned back on even after replacing the unit here is the new solution:
The reason the SRS light turns back on is because not only do they have to replace the ODPS unit but also the Seat Sensors in order to completely fix the problem and preventing the light from coming back on. The reason I know this is because after replacing my ODPS unit for the second time, the SRS light came back on. I took it to another dealership and they informed me that the original dealership was only doing half the job by replacing the ODPS unit.
I hope this helps some of you out.
Have a great day
Old Feb 17, 2007
phi5's Avatar
phi5 is an unknown quantity at this point
are you referring only to the Vehicle with side srs?
Old Feb 17, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
yes only vehicles with side air bags have a ODPS unit and this is also in the wrong section
Old Feb 17, 2007
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
where should it be, in the dead as hell threads section??
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
cruisers10
May 12, 2015 10:46 PM
bo_red
Transmission
May 3, 2015 09:14 PM
SimDogg
Nov 27, 2001 04:20 PM
